1st Aug 2020, 1:34 pm | #21 |
Re: Device to simulate a dual rail power supply from a single DC source
Now I must do something that uses the op amp power rail trick for fun, I wonder how using the power pins has a different frequency/phase relationship with a "normal" output pin. Probably not much if a sufficient current is taken.
At work I am (using a current and horrible term) "mentoring" a young, knowledgeable, thinking electronics engineer, I must tell him about this. Every day is a school day! |
1st Aug 2020, 1:51 pm | #22 |
I added a simple 'virtual ground' option thus giving a split supply to one of my old Farnell PSU's. These had three terminals on the front (one is never used and for constant current as I recall).
I used an opamp (741 I think) and pair of small complementary output transistors with simple current limiting for each. So the virtual ground gives a split rail to whatever the main supply is set at and with a 100ma limit per rail. It has proved invaluable over the years. |
1st Aug 2020, 3:10 pm | #23 |
You can get dual rail bench power supplies.
I have got one. It is a real pain if the output terminals get loose though. https://www.vintage-radio.net/forum/...ad.php?t=89688 |
16th Aug 2020, 5:31 pm | #24 |
I spotted this and it looks promising for a low current opamp job, I think it would work as well with an LM386? because I have a few looking for a job to do.
Does the potentiometer have to be 1 meg? A. Last edited by bikerhifinut; 16th Aug 2020 at 5:32 pm. Reason: additional query |
16th Aug 2020, 5:43 pm | #25 |
I don't think the opamp would be very happy driving all that capacitance, electrolytics may have enough series resistance to make it work.
16th Aug 2020, 6:26 pm | #26 | |
A. |
16th Aug 2020, 8:09 pm | #27 |
Back to I think the original enquiry, not sure if anyone has already suggested the device but I have used a couple of NMA1215SC units in the past, single 12 Volt in that particular part provides plus and minus 15 Volts at 100mA, there were other outputs as well such as the NMA1212SC for 12 Volts etc.
Adrian |
16th Aug 2020, 9:08 pm | #28 |
A few years ago, a power op-amp like the L165 could be used for this application.
Here's the example from the datasheet :- Andy
G-QRP #12697 |
16th Aug 2020, 11:07 pm | #29 |
That looks more like it.
Is the L165 still a current device? If not what is a suitable currently available option? The circuits a bit more sophisticated than the one I spotted but looks much more like what I need and shouldn't take up too much space. Andy |
18th Aug 2020, 11:06 am | #30 |
I've ordered 5 x L165 from eBay, it seems nobody over here supplies them any more.
I hope they are genuine, they were only £9.50 all in though so its basically 2 pints and a bag of crisps that currently I am not enjoying regularly. When they arrive I shall report back with results as I feel sure there are others in my situation. A. |
