Old 9th Jul 2020, 6:27 am   #41
Default Re: FM signal boosting
Some UK outlying VHF/FM stations had a receiver with an antenna aimed at a main station. This was either used as the source for rebroadcast, or as a back-up if the minor station's audio feed went down.
I wonder what sorts of distances were covered?
Of course, both antennae would be on tall masts, but the poor receiver would be very close to transmitters banging away in the same band.
Old 9th Jul 2020, 6:46 am   #42
arjoll
arjoll's Avatar
It'd be a proper relay receiver. We use an Inovonics one to do linking between Gore and Mid Dome, but it's at an intermediate site with a view of both to save the cost of two STLs. Picks up Gore off-air, STL to Mid Dome (pic is with a temporary STL tx when our main RVR one died). Composite out, composite in to the STL so MPX and RDS are passed.
It's an oldie now, I see the current version is the 650 with more bells and whistles.
RVR used to do one as well, based on the same form factor as their RXRL-NV STL receivers, but it doesn't seem to be in their catalogue now.
arjoll is offline   Reply With Quote
Old 9th Jul 2020, 8:43 am   #43
SeanStevens
SeanStevens's Avatar
This is fascinating stuff! Mainly because of my late fathers love of classical music and R3.
He had a good enough everything (details are sketchy, but there must have been an FM antenna) to record especially interesting R3 content onto cassette and still be happy with the result.
We lived in Kent, near the top of a hill, so I guess strong signals were at hand - which from this post seems to be the best starting point.
I'm diametrically opposed here in BANES (BA1). I live in a bowl, with hills literally all around. I'd like to know where I'm actually getting a signal - it is probably bouncing off of seagulls!
I don't listen to R3 or classical music much - preferring to select the music I listen to and receive mainly talk radio (R4). This shows up interference excellently and my NAD 4020A is being fed mush from my room mounted di-pole. I've seen the stereo light go on once or twice - but that was tuning through the scale listening for something different (the Archers must have come on!).
My mind is racing (as usual) to a solution to this and the OP's issue.
If there is enough signal (enough being difficult to quantify) then there is not an issue, but when on the margins of decent reception, height seems to be important.
This height leads to long lengths of coaxial, which can negate the reasonable signal back down to marginal! I see an equation in there somewhere!
Please feel free to shoot this idea down - it no doubt has been done before, originality is difficult!
If you:
Received the reasonable signal (at height)
Rebroadcast it at a different frequency (double it as a poor example)
Then with a matching receiver capture it back in the house
Halve the signal back to originality
Put the signal into your receiver
you surely would have the best of both worlds. Modern surface mount components could have this done in the size of a box of household matches.....
It might seem overcomplicated, but the units could be calibrated to be matched, so barely any quality loss would be added to the mix.
Possible? Well my wireless headphones work up at the end of the garden, they are the same technology . . .
SEAN
There are only 10 types of people, those who understand the binary system, and those who don't.
SeanStevens is offline   Reply With Quote
Old 9th Jul 2020, 9:02 am   #44
Ted Kendall
In that case, why not just use a masthead amplifier? They say in (American) motor racing circles that there is no substitute for cubic inches - in stereo FM reception there is no substitute for uV/m.
Ted Kendall is online now   Reply With Quote
Old 9th Jul 2020, 9:09 am   #45
Nuvistor
Nuvistor's Avatar
A low NF mast head preamp would probably be a lot simpler solution to overcome feeder losses.
Crossed post with Ted but same thoughts.
Edit. There are always going to be areas where good stereo is difficult but mono requires a lot less signal, I would rather listen to clean noise free mono than hissing distortion in stereo.
Frank
Last edited by Nuvistor; 9th Jul 2020 at 9:12 am. Reason: Info about stereo reception.
Nuvistor is online now   Reply With Quote
Old 9th Jul 2020, 10:06 am   #46
paulsherwin
paulsherwin's Avatar
The BBC used modified Revox B261s for their emergency backup chain for about 20 years (David owns and has restored an ex BBC example). The hops were 40-60 miles, but were in mono and they had good aerials on tall masts. Nevertheless, the signal was pretty grim by the time it got to northern Scotland.
This was actually activated in anger for several hours about a decade ago when a combination of human error and aircon failure took down the standard Nicam distribution system, which is supposed to be multiply redundant.
I think they use satellite backup now.
paulsherwin is online now   Reply With Quote
Old 9th Jul 2020, 10:20 am   #47
The mast-head preamp has to be worth a try.
Feeder cable loss before you get any amplification in has exactly the same effect as path loss. So 3dB cable loss is the same as living 41.4% further from the transmitter. If you then add a masthead preamp, you take out this much loss. If your preamp has a lower noise figure than the tuner (not usually very difficult) then you gain even more.
Unlike bigger, gainier antennae, the preamp doesn't take any significant space.
So the priority is to get the best antenna you can, pointed accurately or on a rotator, have it up outside in the clear with minimum cable length to a weather sealed preamp (possibly peaked for the stations you want) and then good quality cable to the tuner indoors.
Look for cable with a foil layer under the braid. Satellite TV grade.
Old 9th Jul 2020, 5:18 pm   #48
Jonster
Originally Posted by paulsherwin View Post
75 miles is a very big distance for FM, even with a good external aerial and a big transmitter.
I've just done a quick calculation, that's 120km.
I've checked on a map and its not 75 miles/120km, its 40 miles/64km.
Jonster is offline   Reply With Quote
Old 9th Jul 2020, 10:11 pm   #49
It's what lies in between that can be the make-or-break issue.
Where I live, some of the houses do not have a clear path to the nearest TV transmitter and therefore use a more distant one, without any problems. Along came channel 5 and their retuners. In these houses they swung the aerials round to the one they'd been told to use in that postcode. No signal. So they sent round an aerial fitter who tore down the perfectly fine antenna in bent pieces and fitted a broadband lower gain one. Still no signal, but with careful adjustment an unwatchable picture was achieved on the 3 higher power channels. They beggered off muttering about sending a specialist. Aye, right.
I sorted a couple of neighbours out. Straightening and welding back together the remains of the antennae which had been literally torn out. Then with the greatest precision, and photographs, I tore out the new antennae exactly as the old ones had been. I tried to get them out in as many pieces. It had been fitted by driving nails through some of the elements into the attic framing.
A quick bit of aiming, being able to see all signal strengths at once on the spectrum analyser, then tune the telly onto a sig gen and I could then do the bit of showmanship of plugging the antenna cable into the telly to have all five channels working with no further twiddling. They had offset the VCR reasonably well, but I provided a few SCART leads and showed people the difference in quality.
All because of someone's over simplification of a coverage area map. And it being blindly followed.
Grrr. One of my neighbours said if the channel 5 people ever came to get their aerial back, she would show him an entirely new way of carrying it back to his van.
Old 10th Jul 2020, 7:13 pm   #50
Jon_G4MDC
Jon_G4MDC's Avatar
I spent time this week in the middle of Dorset. In some idle hours I was doing some SDR experiments with GNU radio and Band 2 FM was the most convenient source of signals - with a helical whip indoors at ground level I didn't expect much.
All I could find were the BBC national stations. Hardly surprising except the frequencies matched the Wenvoe transmitter. Well that just couldn't be - there is steep rising ground in every direction except a gap to the South. The frequency groups of main stations do tend to be re-used on relays but none of the local Dorset ones matched.
The only station I could find that has the correct frequency group is Ivybridge but that is just outside Plymouth. It's a very long path 100km + to the SW but quite a bit is over the sea.
No sign at all of the intended relay for the area which is about 10km South through the gap in the hills. Strange stuff RF.
Jon_G4MDC is offline   Reply With Quote
