7th Dec 2008, 11:43 pm | #1 |
Don't use UV setting glass glue in winter!
I bought some glass glue to repair a dial glass for a VHF90. 'just leave in the sun and it will set in 30s'
Not this time of the year it doesn't...6 hours of 'sunshine' and nothing Slung the UV lamp out years ago and I'm a bit too old for disco's. |
8th Dec 2008, 1:02 am | #2 |
Re: Don't use UV setting glass glue in winter!
Apparently some of they there new fangled compact florescent things give out quite a bit of UV (the sort without an external globe). There was a "media scare" about it a while ago.
Maybe worth sticking it under one of those for a bit.
Chris |
8th Dec 2008, 9:43 am | #3 |
What about one of those bank note checking gizmos from Maplins (MW36P)?
Dave G1AGK. My perception is my reality! |
8th Dec 2008, 10:10 am | #4 |
Pardon me for butting it, but is the dial made of glass and not perspex or acrylic? Isocyanates are very particular.
8th Dec 2008, 5:17 pm | #5 |
If you get really desperate I have 40 Watts of UV here. You would need to post me the glass.
It is amazing what can be seen under this light especially with bank notes. |
8th Dec 2008, 5:31 pm | #6 |
UV LEDs are available too now (see eBay etc.)
Nick. |
8th Dec 2008, 5:48 pm | #7 |
Service Trading - a long standing advertiser in EPE etc - used to do little UV fluorescent tubes, about 15 watts. I bought one and still use it to etch PBCs occasionally.
Failing that, a lot of halogen desk lamps had a UV shield and a warning about removing it, so if you've got one of those, it would be worth a try without the shield. Arc welders throw out enormous amounts of UV. OK if you've got one handy in the garage. LEDs and banknote proving lamps - possibly. The difficulty with a problem like this is that unless you have a lot of glass to glue, you don't want to spend much and have the gear hanging around. You just want an improvised, cheap solution. Pete. |
8th Dec 2008, 6:06 pm | #8 |
If you have an EPROM eraser (that's almost vintage now!) it has a UV source. Be very careful if you run this sort of tube out of it's box. It's germicidal UV (short wavelength) which is VERY dangerous to your eyes and not at all good for your skin.
8th Dec 2008, 7:42 pm | #9 |
I'd also suggest looking at the neighbours to see if any have a pond. The water sterilisers are UV.
8th Dec 2008, 8:48 pm | #10 |
Some of the above suggested sources of UV may well work, but bear in mind that 'UV' covers a pretty broad range of wavelengths, and that the glue is probably fairly specific in its requirements.
8th Dec 2008, 9:01 pm | #11 |
I sold my UV eraser with a spare tube too and there was a tube to purify the water in the pond filter but that is dead.
I'll try the halogen and flourescent lights to see if they work. If not I'll have to get a spare for the pond filter and try that - don't have a pond anymore but at least it has a possibility it will be used again. |
31st Dec 2008, 7:33 pm | #12 |
Hello,
pardon me, but I think the same direction as Humphrey: UV-Cure glues are common for Perspex (Lucite, Plexigls etc) but rather uncommon for real glas. Regards Georg |
1st Jan 2009, 2:35 pm | #13 | |
Administrator
Maplin sell it here http://www.maplin.co.uk/Module.aspx?...C=SO&U=strat15
