Old 15th Mar 2011, 9:07 pm   #41
Tazman1966
Tazman1966's Avatar
Default Re: Feguson 992T
Nice to see your good results on the Aurora thread. What else do you need to do with this Fergie?
All the very best,
Tas
Tazman1966 is offline
Old 15th Mar 2011, 10:05 pm   #42
Andy Doz
Andy Doz's Avatar
Watch it
Andy Doz is offline
Old 17th Mar 2011, 8:49 am   #43
Andy Doz
Andy Doz's Avatar
Default Re: Ferguson 992T
Develops a bit of a hum bar after being on for about an hour ... I'll give some attention to the main smoother I think.
Andy Doz is offline
Old 17th Mar 2011, 8:58 am   #44
ppppenguin
ppppenguin's Avatar
Could just as easily be HK insulation breaking down in one of the valves as the set gets hot. If you can safely* 'scope the HT rail that will show any increase in ripple. I appreciate that TV repairers of the 1950s would never have used a 'scope for this job, even if they had a 'scope at all. They would probably have bridged extra caps across the reservoir and/or smoothers to prove the point.
*Just because I've got an isolating transformer and know how to use it safely doesn't mean that all our vintage TV enthusiasts are in the same position. Lifting the earth off the 'scope is something that we cannot recommend, even if many of us have done it and got away with it.
ppppenguin is offline
Old 17th Mar 2011, 3:27 pm   #45
Andy Doz
Andy Doz's Avatar
Will do ... never have lifted an earth in my life.
Andy Doz is offline
Old 17th Mar 2011, 6:51 pm   #46
murphyv310
murphyv310's Avatar
Hi Andy.
To elaborate on Jeffrey's post, lifting the earth was the norm in some workshops for years. It certainly would be very much frowned upon now and for those less technical it is very much not advised.
As I don't know your skill level, you cannot scope anything in a TV with a "live chassis" (no matter what side is connected to the mains) when it is in direct connection to the mains as the scope is earthed. The only way is to run the set via an isolating transformer.
A qualified engineer who knows what he is doing may do it the old fashioned way but he will have a work area free from any other live equipment, will have an insulated floor and one hand in his pocket and will be 110% certain the TV's chassis is connected to neutral.
Cheers,
Trevor.
MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member
murphyv310 is offline
Old 17th Mar 2011, 8:11 pm   #47
Andy Doz
Andy Doz's Avatar
There's a 1.8KVA isolation transformer permanently under the bench. Wouldn't be without it.
It's the Electrolytic BTW. I'll order up something to take it's place. Running a bit low on Higher voltage caps of late ...
The first cap after the rec and before the L is very low in value. That will probably explain the motorboating at low volumes as well.
Andy Doz is offline
