7th Feb 2016, 4:19 pm | #1 |
JVC HR-D120EM not accepting tape!
Hello (again). I have a JVC VCR model HR-D120EM which died just yesterday! The machine powers on but I can't insert a cassette in. If I insert the cassette manually by turning the gears, the machine recognizes it but when I press play, The solenoid clicks but the tape loading motor doesn't take any voltage at all! I checked the main and the secondary power supply voltages and all of them are fine according to the service manual. Any thoughs? Thanks
Fivos |
7th Feb 2016, 5:32 pm | #2 |
Re: JVC HR-D120EM not accepting tape!
Just an idea, check for loose connectors on bottom board, had two machines that have failed after belt changes because quite a few connectors are removed to gain access.
7th Feb 2016, 9:04 pm | #3 |
I double-checked that and I re-soldered the connectors too. Still notihng.
7th Feb 2016, 10:36 pm | #4 |
Hi Fivos
Sorry to butt in on your thread I used to repair video recorders in the distant past and found JVC machines do have a habit of blowing circuit protectors just for the hell of it. They are usually in the power supply and look like a bit like a transistor but with only two legs. |
8th Feb 2016, 2:36 pm | #5 |
Thanks cubdiesel44. Here's some pictures of the machine and the power supply schematic.
Fivos |
8th Feb 2016, 5:17 pm | #6 |
Hi
Often the circuit protectors are additional to the manual. They are designated CP and often just fail. The confusing number is x 400mA - e.g N(or F)15 is 600mA, N38 is 1.5A and so on. Glyn |
8th Feb 2016, 5:34 pm | #7 |
Hi Welsh. The regulator PCB on the back of the machine blew a 2.5A fuse yesterday and I replaced it with a 4A one. Is it electricaly safe now or will it cause problems (damage, electrocution, fire)?
8th Feb 2016, 5:41 pm | #8 |
It is always best to replace the fuse with the exact type.
Should a short circuit occur the correct fuse will blow instantly. |
8th Feb 2016, 7:01 pm | #9 |
Yes! That's the problem! I read the service manual carefully and I found that there's an ICP-F15 circuit protector on the bottom PCB (Mechacon, audio, servo). I checked it with my multimeter and it is open. Do you know where to find a replacement? Thanks.
8th Feb 2016, 7:03 pm | #10 |
