9th Jan 2016, 9:30 pm | #1 |
Flyback swap same properties different pinout?
Hi I have a really old TV I'd like to repair it has a burnt flyback, TV is a 1984 Pulser (Canadian Tire) manufatured by Daewoo Chassis c101a, picture suddenly shrunk, blurred and faded to black, smoke came out from the set. I immediately switched it off. After opening the back I switched back on for a second to see where the smoke was coming from the flyback.
The thing is the original part is a Murata MSH1FBA05 I can't find one any where or a direct fit replacement, I did however find one that seems electrically equivalent but the pinout is different it's a Daewoo DCF1551, coincidentally the TV chassis is also a Daewoo. I know of course that I can't put in directly on the board but is it ok or safe to use wires to take each connection to the right place and glue the flyback to the board so it won't rattle around? Here are the pinouts: BRAND: MURATA____________DAEWOO REFERENCE: MSH1FBA05_____DCF1551 VOLTAGE: 103V_____________103V PINS: 11___________________11 PIN1: +B 103V______________NC PIN2: NC___________________+B 103 PIN3: GND__________________H PIN4: H____________________175V PIN5: 175V_________________16.5V PIN6: BOOST_______________AFC PIN7: 16.5V________________GND PIN8: AFC/BLK_____________ABL PIN9: ABL_________________40V PIN10: COLLECTOR_________BOOTER 123V PIN11: 40V________________COLLECTOR Thanks. |
