30th Dec 2015, 6:47 pm | #1 |
Christmas holiday TV testing
Hi All,
Having got married last year I have since not had much time to visit my parents' place (where most of my TV sets still are) and power up my old sets. This year I had a quick go at powering them up. Here are the results:- 6" 1938 Cossor 54. Overhauled 6+ yrs ago, last used 3 yrs ago. Worked as well as it did (I never had it working perfectly), no new faults. 9" 1949 Invicta T102. Overhauled 2 yrs ago, last used 1 year ago. Sound only, EHT generator failed 9" 1949 PYE B18T. Overhauled 10 yrs ago, last used 6 mths ago. Worked perfectly 9" 1949 Ekco TS188. Overhauled 5 yrs ago, last used 1 year ago. Worked perfectly 14" 1952 KB KV35. Overhauled 2 yrs ago, last used 1.5 yrs ago. Worked, but blurred off tune pictures 9" 1956 Ecko TMB272. Overhauled 10 yrs ago, last used 3 yrs ago. Worked perfectly, amazing picture 9" 1957 SpencerWest 957. Overhauled 10 yrs ago, last worked 3 yrs ago. Worked, but sound a bit weak 11" 1964 BRC900. Overhauled 8 yrs ago, last used 6 mths ago. Worked, but noisy system switch 11" 1964 KB KV003. Overhauled 10+ yrs ago, last used 3 yrs ago. Worked ok, but noisy system switch 9" 1967 Sony TV9-306UB. Overhauled 10 yrs ago, last used 3 yrs ago. Failed, line timebase/PSU squegging on 405 lines 16" 1967 BRC981. Overhauled 15 yrs ago, last used 2 yrs ago. Worked perfectly 17" 1969? BRC1400. Overhauled 10 yrs ago, last used 1.5 yrs ago. Worked, but lack of width Cheers Andy
www.youtube.com/user/andyvalve100 Last edited by beery; 30th Dec 2015 at 7:02 pm. Reason: posting mistake |
30th Dec 2015, 7:33 pm | #2 |
Re: Christmas holiday TV testing
That's a good result! Those little Ekco TMB272's are brilliant sets, I waited 9 years to get mine going. It's by far the best 405 line telly I've got. All my sets are in storage at the moment, so no firing them up for a while.
Regards, Lloyd |
30th Dec 2015, 10:11 pm | #3 |
Hi Lloyd,
It was a good result yes, but dissapointing in places. The reason being that the KB KV35 was restored not that long ago and was capable of really good pictures, though maybe it is just a poor contact on an RF valve. The Invicta T102 was re-restored not long ago, that is I took one of my earliest restorations and did it again, this time using period components (including oil caps that were re-stuffed). It is worrying that there is no EHT, though there is some 10KHz whistle (In this set there are two 10KHz output stages fed from the same oscillator, one for the line scan and one for the EHT). It is also not long since I had last tried the set and seen it working. The Sony had undergone complete replacement of the electrolytics including the hard to get to resivoir caps. The squegging fault then showed itself and was cured by replacing the rectifier diodes in the PSU section, so why has the fault returned? But yes the TMB272 was a pleasant supprise Cheers Andy
www.youtube.com/user/andyvalve100 |
31st Dec 2015, 1:32 am | #4 |
We had a TMB272 in our caravan on our honeymoon at Tavistock in 1963, you need a very big battery to run it from your car and still be able to start it in the morning!
Peter |
31st Dec 2015, 5:42 pm | #5 |
Not a bad result, I dug out my 1960 Pye V200 only to find the picture to be weak and lacking sync, it was fine a couple of years ago
My Bush TV22 had also not been powered up for at least two years, but worked perfectly all evening. I have well over 50 sets, some have not been powered up for five years, so I am expecting to have a few issues when I drag them out. The most amazing set was an unrestored Pye LV20 which had not been used since 1960, it powered up fine with a decent picture after sitting in a loft for fifty years! I too am not surprised that the TMB272 fired up fine, my unrestored set still performs well despite all it's old leaky caps, even the radio is still working. Mark |
7th Jan 2016, 8:58 am | #6 |
Hello Mark Pirate,
Would that PYE LV20 be the TV we both know & love? LOL.... Regards, Maria. |
7th Jan 2016, 2:33 pm | #7 |
Hi Maria,
No not your set, That is a B18T. The LV20 is the newer model It should be making it to the bench in the next couple of months once I have finished my TV22 restoration. I really must make it my new years resolution to power up and use my sets on a more regular basis Trouble is there is so many of them... Mark |
7th Jan 2016, 3:43 pm | #8 |
...Nice problem to have though...
Regards, Paul
...No, it's not supposed to pick up the World Service, it's not a radio! |
