Old 17th Oct 2015, 5:49 am   #1
alm7rom
alm7rom's Avatar
Location: Al-Kharj near Riyadh, Kingdom of Saudi Arabia.
Thumbs up Repair Sony Trinitron TV-VCR Model KV-14VM1
hi
i got this 14 inch tv the screen is not bad this tv made in 1993 it's now 22 years old
i see like this tv before in store years ago i don't like it because if the vcr have a problem
you got to take the tv with it and you have one tv at home this is a bad made
ok now the problems and the repairs
the problem is in the vcr don't take the tape i open the tv and see under the mechanism
the belts its so bad i replace them there are 3 belts you can see the picture
and another problem is the black part on the capstan is cut to half i put a glue its fix the problem
ok now the vcr take the tape but another problem in the way
i hear stick gear sound the gear is white sticking between two big gears the teeth is broken see the picture
i fix it using knife between the teeth to make it out As much as possible and i clean the mode switch
and i put grease on all gears and its work great all function works ok ff rew eject pause
the amazing in this vcr its have a good quality picture in pause ff rew slow Although two heads
sorry for my bad English if i wrong Corrected me
and for my bad picture its from my old mobile
Regards
http://www.imagebam.com/image/f68a3e441191504
http://www.imagebam.com/image/27016e441191506
http://www.imagebam.com/image/b5074e441191508
ID:	114356   Click image for larger version
ID:	114357   Click image for larger version
ID:	114358   Click image for larger version
ID:	114359   Click image for larger version
alm7rom is offline
