6th May 2015, 6:37 pm | #1 |
How could I make a possible analogue home transmitter?
What I'm talking about is I have these two analogue televisions, both a Beovisions, one from 1990 and one from 1974 and the 70's TV is colour. Since they have an antenna in both of them I was thinking mostly for the TV box and VCR machine and blue-ray player so I can watch on both televisions without needing extra wires, theyre all SCART components.
7th May 2015, 8:12 am | #2 |
Re: How could I make a possible analogue home transmitter?
What you want is a modulator. Any old VCR will do the job. Some people have had success repurposing the TV modulators from PlayStations, camcorders or home CCTV systems.
7th May 2015, 8:31 am | #3 |
I use a little transmitter called a 'Video sender', this takes a composite video signal and audio from a video recorder, DVD player or digital box and sends it to the TV.
All that is needed is a set top aerial on the TV, and tune to the transmitter. Mine is for the UK 625 Pal standard, but you may find one to suit your TV system. Mark |
20th May 2015, 1:06 pm | #4 |
Can it take stereo audio too?
20th May 2015, 1:51 pm | #5 |
I don't think SCART supports Blu-Ray; it'd be a violation of the anti-copying protocols (which is one of the reasons HDMI was introduced).
20th May 2015, 1:53 pm | #6 |
this blue ray have option for composite out,
20th May 2015, 2:04 pm | #7 | |
That said, SCART connectors are becoming much less common on both Blu-ray and upsampling DVD players, particularly at the bottom end of the market. This is just a cost cutting measure. |
20th May 2015, 2:26 pm | #8 | |
Mark |
20th May 2015, 3:15 pm | #9 |
Mark can you still buy that model? I had one exactly like that over 20 years ago!
Lee |
20th May 2015, 4:09 pm | #10 |
There are stil a few scart parts out there, so it is possible yet but how is that copyright related? i simply want a way to broadcast to the analog stereo tv's.
20th May 2015, 5:22 pm | #11 |
Hi Lee, I bought mine years ago from a friend, and recently bought an identical one from a boot sale.
These date from the early 90's, but worth keeping an eye on ebay for one. I am sure it is possible to build something similar, the circuit looks pretty basic and could probably be improved upon. I would certainly like a 405 VHF version! Mark |
20th May 2015, 6:35 pm | #12 |
The problem you have just using any of the available modulators is that the sound will only be mono. Not sure it your TV would be NICAM or a Zwie-Tone type of arrangement.
I don't recall any stereo modulators on the domestic market.
6.3v on my heaters is no longer enough to get me going in the morning!! |
20th May 2015, 6:44 pm | #13 | |
Chipsets for receiving / decoding NICAM must have been abundant as every NICAM compatible stereo TV would have needed one, but generally speaking, NICAM encoding would normally only have been done by the broadcasters. A UHF video sender which incorporates a NICAM encoder is probably a rare thing indeed. It's the sort of exotic project which Elektor or ETI (hobby electronics magazines) might have possibly have tackled at one time or another - maybe someone has just such an article lying about? |
20th May 2015, 7:41 pm | #14 |
There was a Nicam encoder IC, MC44C404 from Freescale (formerly Motorola) which could be used with the MC44BS373/4 UHF modulator to create a suitable signal for NICAM receivers but the datasheet is only the advance version so I don't know if it ever went into full production.
Keith |
20th May 2015, 8:03 pm | #15 |
Keeping it legal I use the built in modulator of my VCR, via an aerial distribution amp to feed an analogue UHF 625 line PAL signal to all my older 625 line sets around the workshop. I then feed into the VCR socket via a scart switch my Freeview box and DVD so I can watch any Freeview channel plus DVD and of course watch video tapes and record programmes on my VCR. I considered using some kind of video sender for the rest of the house but changed my mind as the number UHF TV channels free from local Freeview transmitters are very few with the risk of causing interference being quite high.
I have recently bought a modulator, from Amazon. Which covers all the 625 TV channels on VHF and UHF with the sound spacing adjustable from 5.5, 6 and 6.5Mhz, in mono only, which would meet your requirements. As has been said stereo sound is another challenge.
Simon BVWS member |
21st May 2015, 3:45 am | #16 |
There was a NICAM encoder mentioned in this thread: https://www.vintage-radio.net/forum/....php?t=114544; but it was a professional unit not a domestic model.
Cheers, |
25th May 2015, 10:41 pm | #17 |
Are your TVs stereo?
The 1970s one is said to be colour. So is the 1990s one monochrome? Maybe OP only wants to take stereo in and is happy to play in mono. Especially if the TVs are mono anyway! Graham
Half my stuff is junk - trouble is, I don't know which half! |
26th May 2015, 6:01 pm | #18 |
I have a varity of tv's, some stereo, some mono.
29th May 2015, 1:39 pm | #19 | |
Stand-alone A2 stereo modulators are available from firms like Terra. They work on bands I, III and UHF.
Classic TV Show Theme Tunes |
