Old 31st Jul 2014, 10:23 am   #1
IanNVJ35
IanNVJ35's Avatar
Default VHS frequency response adjustment pot
Looking through my Panasonic service manuals for some of their 90's VCR decks I see reference to
"VHS frequency response adjustment"
With the following info as an example;
Test Point: TP3002
Adjust point: VR30005 (SP) VR30004 (LP)
Mode: playback of self recorded SP and LP
Input: Video sweep signal
Tape: Blank tape
Measurement: Oscilloscope
Spec: SP:0+-1 (dB)(90-110%), LP:0+-1 (dB)(90-110%)
Set video sweep signal as shown in and supply video sweep signal to video in terminal.
What I was wondeing is what is the effect of this pot - change of record or playback? Is it an internal sharpness adjust or something more than that?
IanNVJ35 is offline
Old 1st Aug 2014, 8:50 am   #2
IanNVJ35
IanNVJ35's Avatar
Default Re: VHS frequency response adjustment pot
Well I tried it (after marking the original set point). One way the picture got a bit sharper and the other way the picture got a bit softer followed by comet tailing like worn heads.
IanNVJ35 is offline
Old 1st Aug 2014, 11:47 am   #3
flyingtech55
Some VCRs had a 'Sharpness' control under a flap for the customer to twiddle. ISTR when I went on a Panasonic course for one of the VCR models this question came up. The stance Panasonic took was that there was a correct adjustment for that and that anything other than that setting was incorrect so why let the customer twiddle with it.
HTH
Tim
All those moments will be lost in time, like tears in rain.
flyingtech55 is offline
Old 1st Aug 2014, 12:48 pm   #4
PaulE27
PaulE27's Avatar
I had a Philips VCR with a sharpness control. I found it quite useful, and set it differently with different TV sets.
Paul
PaulE27 is offline
