19th Aug 2015, 11:35 pm | #1 |
Swedish Luxor
Somewhere in Sweden is passed this abandoned house while on a car journey. As I have a fascination for ruins I made a stop. The house was almost invisible because of the vegetation and has obviously been abandoned for years. The door was wide open and all windows smashed so I stepped in to take a look. Part of the roof had collapsed and let water in which had rotted the upper floor.
My intention was to "look but not disturbe" but when I saw this Luxor TV standing just a metre from the hole in the floor waiting to fall to it's demise I could not help myself. Strictly speaking this was theft but I prefer to see it as a rescue mission. So in the car it went. Arriving home I wondered why on earth did I bring this home? Anyway I removed the back cover and it was very dusty inside but luckily it don't seem to have suffer moisture damage. I gave it a good vaccuuming, replaced the mains smoothing cap and plugged it into the mains in series with a light bulb. Faint glowing was seen in the valves. Suddenly a loud snap and smoke! The infamous RIFA suppression capacitor had cracked and was snipped out of circuit. Successively fitting higher wattage bulbs the sound came to life and soon a faint raster was visible. Applying full mains power gave a bright nice raster although not filling the whole screen. Now it will get a set of new capacitors before I try it any more. I did not expect it to work at all! |
20th Aug 2015, 12:02 am | #2 |
Re: Swedish Luxor
Back in the day, I'd have changed the PCL805, then gone for the cathode decoupler. That would have cured most of these symptoms. Now it could be almost any of the FTB components, but there aren't that many of them.
20th Aug 2015, 12:26 am | #3 |
Re: Swedish Luxor
A picture of the chassis would help. Rediffusion had Luxor hybrid ctv sets when i worked for them. They were very reliable and produced very good sound and pictures, Malc.
Malc Scott |
21st Aug 2015, 9:13 am | #4 | |
Re: Swedish Luxor
I have not done any fault-finding yet, I would like to start with replacing at least a few capacitors before running it anymore. It has quite a few of the plastic-encapsulated rifa caps, they are all more or less cracked and the electrolytics are probably not too reliable either.
Anyway, the model is "Luxor Revy" type 20200. Valves are: PCL86 DY802 PY88 PL500 PCF802 PCL85 PCH200 A50-120W Quote:
I do not have much experiences with TVs although I have managed to fix a few over the years. |
21st Aug 2015, 9:26 am | #5 |
Re: Swedish Luxor
A lucky find, for you and the set, as you have saved it from a fall.
The CRT looks to be OK. I also remember the Rediffusion Luxor's, they gave good picture and sound. Depending on the model I may still have a circuit, as Malc Scott says a chassis photo would be useful. John |
21st Aug 2015, 9:34 am | #6 |
Re: Swedish Luxor
Well done for saving that. A rare survivor, surely. And it seems to be in immaculate condition, amazingly. It would be fascinating to know when it was last used.
N. |
21st Aug 2015, 8:22 pm | #7 |
Re: Swedish Luxor
Please let me know if you like to have a schematic. I may have it, I am collecting vintage swedish TV sets, just brought a Radiola console (70°) 2 weeks ago home and have a couple of schematics. Great story, these sets have the biggest value in the eyes of the new owner. Best regards, German Dalek
And now something completly different: MARC BOLAN, he was/is the real king of Pop Music! |
21st Aug 2015, 9:27 pm | #8 |
Re: Swedish Luxor
The picture tube seems to be from 1968 and made by Philips.
21st Aug 2015, 10:33 pm | #9 |
Re: Swedish Luxor
Since you took the set from a house with a leaking roof I would change the Rifas ASAP. They can't cope with moisture. I have an old Tandberg that has been in a damp garage for a couple of years. All the Rifas are bad.
22nd Aug 2015, 2:00 pm | #10 |
Re: Swedish Luxor
Totally different to the Redifussion Luxor sets I worked on.
Although the front of the set looks similar. John |
30th Oct 2015, 12:27 am | #11 |
Re: Swedish Luxor
Now two months later I felt for doing some work on this set. I removed all the innards from the cabinet to be able to inspect and clean it properly. It contained quite a lot of sawdust that used to be the house roof insulation and also some leaves and tree needles! Amazingly it is otherwise in good condition and shows no signs of moisture damage despite being in a abandoned leaky house A vaccuum cleaner in the same room was quite rusty but not this item. Anyway this of course pleases me.
All parts are connected with plugs so no soldering was needed to take it apart. The circuit boards was vaccuumed. The CRT got a shower in the bathtub and will soon be remounted. I will have to order some capacitors next week, hopefully there is no major problem with the set German Dalek; Thank you for asking, I don't know if I will need a schematic but if it's not too much problem I would appreciate a copy. |
