Television Standards Converters, Modulators etc Standards converters, modulators anything else for providing signals to vintage televisions. |
3rd Mar 2006, 5:48 pm | #1 |
405 analogue standard converter kit
Good evening,
here is the schematic of the clock board of the do it your self standard converter. The board is routed and I want to give it in production next week. It is planed to use one UVB at the input. It removes teletext and Macrovision from the vertical flyback. The output is usefull for 625 and drives the analogue ccd PCB and separates the 625 sync. The analogue PCB contains the interpolator, the switched delay ccd‘s and one half of the V- sync replace circuit. An other UVB will be used at the output. It contains the other half of the V- sync replace, drives the modulator , is 405 input for the modulator and 405 output of the standarts converter. The colck board generates all neccessary pulses and the clock frequencys for the delay ccd‘s . I am sure there are only a few people who wants to build a converter. So I’ll make only a few PCBs. I’ll build up one with the high and one with the low clock frequency to try out the exact values. Than comes the analogue delay ccd PCB and the kit is finished. Maybe I’ll make a PCB for the modulator too. If you find mistakes or have some helpfull ideas please let me know. Kind regards Darius |
3rd Mar 2006, 11:55 pm | #2 |
Re: 405 analogue standard converter kit
Hi Darius,
This sounds great! I am sure I will be building one of these as soon as you are ready! I think the modulator would be best built as you already do - otherwise how does anyone learn basic RF engineering However, A PCB would make the project more accessible to those members that lack the confidence to have a go from the start! I am just working on a varicap oscillator for the modulator - makes tuning easier...... 73 Sean
4th Mar 2006, 7:14 pm | #3 | |
did you see the OIRT modulator on the german UVB website? It is quasi parallelsound (SO42) and has a switchable oscillator. I hope a kit brings more people back to do it your self. Kind regards Darius |
29th Mar 2006, 4:23 pm | #4 |
Good evening,
the clock boards arrived and I am testing them now. The one at the top is compleately loaded for the low clock frequency, except the V-sync monostables. First I need the delay ccd board to find out their RC values. I am loading the other board for the high clock frequency. Both work fine. Both kinds of synchronus dividers can be loaded, the big and the small one. I started drawing the schematic for the ccd board and I am routing sumultaniously. So I can see what can be loaded and what additional features are possible. The problem for me is, I am limited to 8cm x 10cm board size. I am making a board for the cxl 5508/6M. I am optimistic to get all analogue parts on it, so no other additional board (UVB) is neccessary. I hope. Kind regards Darius |
29th Mar 2006, 9:58 pm | #5 |
Wow these look realy posh Darius i think this would be a good project and yes i would have a go just to say ive built one myself and it will be a good buz to see the results.
very well done. Danny |
29th Mar 2006, 10:11 pm | #6 |
Almost tempting enough to make me want to find myself a 405 telly
30th Mar 2006, 10:57 am | #7 |
I'm happy to hear that there is still some interest.
30th Mar 2006, 11:30 am | #8 | |
How close to completion is the kit, or is is ready? As yet I'm not (no TV), and I am going to wait until I have a Pay-cheque coming in regularly rather than relying on my Student Loan! Sam
Can he lead a Normal life, Doctor? No, he will be ... an Engineer. |
30th Mar 2006, 12:31 pm | #9 |
Hi Darius,
This looks very promising - I look forward to the arrival of a kit very soon! I would be very happy to construct one here. Cheers Sean
30th Mar 2006, 3:08 pm | #10 | |
thus I lost a few month. I think I'll be a bit later than Darryl (L.C.Aurora). I expect the converter kit is finished in May. At the moment I am routing the interpolator. It takes a lot of time. It must all be done by hand, to make it as small as possible and to get a good layout. The autorouter is not able to move the components and change packages. Until this is not possible, forget the autorouter. I am learning a lot making this. This is my second PCB project after making the UVB - Kit. Kind regards Darius |
30th Mar 2006, 6:54 pm | #11 |
You can still put me down for one.
Well done Darius Andi
33, 45, 78, around and around they go...
4th Apr 2006, 4:32 pm | #12 |
http://hometown.aol.de/freddurst50/NW/NwBlatt3.JPG
Hi, I need some help. I want an opamp replacement for Q35. See link attached. In the schematic below you can see how I want to use it. The opamp must work with asymetrical 5V. The input is 0.55Vpp and the output should be -2Vpp (405- vision signal). 8 pin DIP prefered. Any suggestions which one to use? Kind regards Darius |
4th Apr 2006, 5:35 pm | #13 |
Analog Devices AD805x series or AD809x series are both excellent video opamps. You may be forced to use SM parts. Darryl and I have used them professionally.
4th Apr 2006, 6:39 pm | #14 |
Hi Jeffrey, I looked at the AD8052 you suggested in Kat's thrad.
But I did not find a cheap souce. (Kenwood 35.- Euros) The other ones I found at RS are 7,00 € or so. The cost of a BC557/547C is 0,02€. I think I'll make it with transistors again. It takes the same size on board and the amount of external components is the same. Something like this: Kind regards Darius |
4th Apr 2006, 6:54 pm | #15 |
The problem with a lot of these devices is that they are expensive in small quantities. I think the AD8052 is under £1 in 100+ from an Analog Devices distributor.
4th Apr 2006, 7:30 pm | #16 | |
Indeed! ...... I can't see what's wrong with the "discrete" option - There will be good PTH discrete trannys around for a while yet IMHO. It’s, odd, but truly “retro” components like the 741, 555 and 2N2219 trannies, that I worked with when I first started work in the early 80s, are still with us while more modern components have come and gone without a trace. It's looking good Darius.
Chris |
5th Apr 2006, 7:54 am | #17 |
Good morning, Evingar is right.
Over night I decided to use the transistor arrangement. But it'll make a bootstrap input to eleminate the damping of R80 22K Ohms. I want an input resistance of 200K Ohms there. In the MK 1 I used bipolar 22uF electrolytics and now I use 1uF MKT caps.C38/39/40. Kind regards Darius PS: The numbers of the components will change in the next schematics. Don't care about strange values and notifications, because parts are copied with "cut and past" (Eagle). |
5th Apr 2006, 8:27 am | #18 |
Hi Darius,
When was building your converter I found that DigiKey were very competitive for price. http://uk.digikey.com/scripts/DkSear...273428&Site=UK They have high fixed costs up front for handling etc but the part costs are very low so if you are buying a variety of parts (say for the complete converter) then they do make sense. Kind regards, Peter. |
5th Apr 2006, 1:51 pm | #19 |
Hi Peter, I know digikey. But I decided not to use the opamp.
Three SMD parts (the cxl's) are enough for the kit. I think it is much easyer to load three transistors. Following now is the V- sync replace and modulator biasing stage an inverter for the input signal to give a vision signal on the converter bypass switch Q15. Than I'll look how much space is left on board to add some other features. Kind regards Darius |
7th Apr 2006, 3:49 pm | #20 | |
Next is the vision inverter for the bypass mode, (two transistors) and a switchable colour filter at the input. (three transistors, switch and schmittrigger) If there is space left, I'll make a second vision input. Or what ever. Suggestiones are welcome. I think it is better to say 10KHz vision for 405/441/455etc. and 16KHz vision for PAL/SECAM/NTSCetc. If you find mistakes, please let me know. The output stage is similar to the UVB, a second output a filter (switched off in bypass mode) and the sync replace is added. Hope you do understand what is going on. Kind regards Darius |
