Clubs, Groups and Societies For discussions about various clubs, groups and societies relating to our hobbies, such as the BVWS (incl RetroTechUK), BATC, RSGB, APTS, CLPGS, THG, TCC, BECG, MCR21 etc. This is NOT an official forum for any of these organisations. |
10th Feb 2020, 3:30 pm | #21 |
Re: Harwell rally 9 February
This is an early one circa 1974 by the looks. Has nuvistor front end. I'll do a thread on it once I've worked out the situation. At the moment the mains lead is the main issue. There is none! So it's a case of modification for IEC inlet or add a captive lead (yuck)
10th Feb 2020, 5:02 pm | #22 |
Ah, you'll have the 'NEMA' style mains connector.
The cables were rubber with a moulded rubber connector and many have gone rotten by now. I have a few good ones, but they're all for period instruments. Filing the hole for an IEC type is the way to go. David
10th Feb 2020, 6:56 pm | #23 |
That’s the one. I measured up and a C6 connector is close. I might go that way as it’ll probably stop me from having to mutilate the chassis.
10th Feb 2020, 9:53 pm | #24 | ||
David |
10th Feb 2020, 10:29 pm | #25 |
I'm not sure it's 1960s. There are 74 date code power supply cans in it and the meter is dated 73. It's a bit of a weird one. The chopper PCB also has 74 date code parts in it. Perhaps it was made out of left overs
Yes PH-163. Unobtainium, or at least too expensive to bother. C6 looks like it nearly fits in the hole so I can probably forge an adapter plate for it. Nice to see some fellow TEA members here as well! |
10th Feb 2020, 11:34 pm | #26 |
Just had a better look at the pictures on the TEA thread (eevblog), the PSU PCB at the back has a couple of 65 date code capacitors & a transistor, the side TC PCB also has a 65 date code cap.
The middle chopper amp PCB (green colour) has the 74 codes, that PCB has the newer & smaller sized optical chopper block, I suspect it's been replaced at some point. One of mine has been updated with a much later 1980's solid state chopper PCB, but still has the nuvistor PCB. Also I never noticed before, but the power transformers use ribbon cables. David PS, try a wanted post, someone may have a spare PH-163 power lead. |
11th Feb 2020, 12:42 am | #27 |
You are indeed correct. I appear to have fudged my notes. Doh! Was in a hurry so I could go play with that 2245.
The power transformer does indeed use the ribbon cable. Not sure I’m too happy about that. I prefer something a little heftier for the mains wiring. |
