Old 27th Nov 2019, 11:26 pm   #21
ben
ben's Avatar
Default Re: Record Player ID? Identified as a Fidelity HF42 “mini player”.
Good work!
As a lad in the early 80s, it seemed everyone I knew had that HF42 player. Had a couple myself, no idea what happened to them.
There were about three versions of the amp PCB (possibly earliest with transistors, then two different ICs?) and two deck variants. ISTR The earlier ones had a white centre adaptor and 16 rpm speed.
I always thought back then it was a pity there was no headphone output so you could connect it to a better amp or speaker!
With this type of player, if there is a risk of the stylus being damaged by landing on the deck plate (if used by children, for example) I usually put a small strip of something soft along its travel plane! The UA15 had this.
For reference: The x5m cart will take ST12, ST14 (both LP and 78 tips) and ST15 (dual LP/LP) or ST19 (single LP tip).
Regards,
Ben.
ben is offline
Old 28th Nov 2019, 8:04 am   #22
stacman
Nice to see inside the unit, even though basic, are they CTS pots in there? Decent if so for such a unit like this, can't see the modern equivalent nowadays having them.
Regards, Alan.
stacman is offline
Old 28th Nov 2019, 8:14 am   #23
thermionic
thermionic's Avatar
.....interesting to see a metal rectifier being used!
I think you have an early version there, Graham, as I’m sure the one I had as a kid used a TBA810 as the audio chip.
Cheers. SimonT.
The honesty of imperfection..........
thermionic is offline
Old 28th Nov 2019, 12:12 pm   #24
Station X
Station X's Avatar
Originally Posted by ben View Post
Good work!
Thanks for the info. My player does have a 16 RPM speed. It's fitted with a dual LP stylus. I don't know whether it's the original fit. I can't imagine many owners of these players playing 78's though.
Graham. Forum Moderator
Station X is offline
Old 30th Nov 2019, 10:43 am   #25
af024
I wonder if any battery operating ones exist? I mean it looks like there was a design intent to have such a version by the very fact that the injection moulding of the compartment has battery symbols in it etc. Of course the motor would have to be changed wouldn't it. I must have seen many 10s of these in the flesh and probably 20+ photos too, but I've never seen a battery one. It's all very mysterious.
Now where on earth did I remove that from?
af024 is offline
Old 30th Nov 2019, 4:24 pm   #26
ben
ben's Avatar
According to forum member Grubhjead's catalogue, a battery one was made but for export. see here.
Regards,
Ben.
ben is offline
Old 1st Dec 2019, 10:07 pm   #27
kirstyd
There's a red battery cover for this model on Ebay right now.
kirstyd is offline
Old 2nd Dec 2019, 8:50 am   #28
Station X
Station X's Avatar
Thanks for drawing that to my attention.
Old 2nd Dec 2019, 8:55 am   #29
Station X
Station X's Avatar
Regards, Alan.
Yes Alan. They are CTS pots as the picture in post #17 shows.
Old 6th Dec 2019, 1:18 pm   #30
Station X
Station X's Avatar
I now have a lid for the battery/mains lead compartment. Just need to turn up a fixing screw and cross pin for it.
Old 7th Dec 2019, 1:12 am   #31
teetoon
Hi Graham. Don't know if you've seen this https://www.ebay.co.uk/itm/1970-80-s...0AAOSwFChdngd~
It's the advertising leaflet that I thought might be interesting along with the recipt.
I didn't realise they were still available in 1980.
David.
teetoon is offline
Old 15th Jan 2020, 4:27 pm   #32
Station X
Station X's Avatar
This now has a lid for which I made a coin operated fixing screw.
I rather like this minimalist player, but I don't think I'll be keeping it.
ID:	197160   Click image for larger version
ID:	197161   Click image for larger version
Old 15th Jan 2020, 7:13 pm   #33
Techman
Techman's Avatar
Excellent work, Graham.
I know what you mean about these little players.
Techman is offline
