Old 27th Nov 2022, 9:03 pm   #1
Radio_Doctor
Radio_Doctor's Avatar
Default Magneta Master Clock Question
Wasn’t sure whether to post in telephony?
I own a nice Magneta Master. Works perfectly on 4.5V via adaptor wall wart.
I want to set up 2 or 3 slaves. I have attached a photograph of the Dictograph slaves I hoped to wire in. They have 20V on the clocks? Are they suitable for connection? Any advice appreciated.
Many thanks Kneale
ID:	268895   Click image for larger version
Last edited by Radio Wrangler; 16th Dec 2022 at 6:59 am. Reason: typo in the title
Radio_Doctor is offline
Old 27th Nov 2022, 9:42 pm   #2
Radio_Doctor
Default Re: Magenta Master Clock Question
I clearly need to understand more about this system. I have a great manual somewhere but can’t find it!
I have 2 sorts of slave clocks. Two of the Dictograph types photographed above. 20V, 295 ohms across terminals. One older type, no voltage 31.6V across terminals.
Any advice on where to start wiring these to the master appreciated.
Old 27th Nov 2022, 9:47 pm   #3
Robsradio
I don’t have one of these, so can’t provide any help, but ask a few questions.
I believe the movements were 20 v and wired in parallel. Whether the slaves were driven from the master clock contacts would be doubtful as they are only light. The contacts would have driven a relay, which in turn would run the slave circuit with 20v pulses. You mention the clock works on 4.5v, that sounds righty fit the pendulum drive coil, what voltage is stated on the rear of the pilot slave movement?
Rob
Are the Dictograph slaves unipolar or alternate polarity?
Robsradio is offline
Old 27th Nov 2022, 10:06 pm   #4
Radio_Doctor
Many thanks. I used a 4.5v adaptor after reading the manual I can’t find….
The pilot slave (assume meaning one in the master clock has no voltage written on it.
The dictographs have 20V, no voltage on the other older one with bevel glass front.
Not sure about the final question. Have attached photographs of the coils in case that helps?
Kneale
ID:	268904   Click image for larger version
ID:	268905   Click image for larger version
Old 27th Nov 2022, 10:37 pm   #5
Robsradio
Looking at the photos, the first one I’m not certain whether it requires an alternate polarity pulse or uni polarity. The other two photos show a conventional uni polarity ratchet type slave, this will advance with every application and removal of power, the alternate polarity? slave would need the polarity switching every impulse for it to advance.
If you have a lab PSU just apply and remove the power and see what happens, start off with a low voltage if it’s not known what it should be.
Enjoy
Old 28th Nov 2022, 11:44 pm   #6
Radio_Doctor
Many thanks for that. I incredibly don’t have a variable bench power supply but know someone who does. Job for next week I think.
I finally found the site I used when I first fitted the clock. It’s very helpful:
http://www.rogerj.co.uk/PO%2036.htm
I’ve also attached a photo of the current wiring. Looks like the dial slave is running directly off the pendulum supply.
I hope to initially run one slave. If permitted might run the other 2 into the house but that’s still under negotiation!
Thanks again for advice.
Old 29th Nov 2022, 9:11 am   #7
Robsradio
Hope you find the answers regarding the slaves when you have access to a psu. I wonder if the pilot dial had a special coil wind to suit the pendulum drive supply voltage possibly? I have a Gent PO36 but this doesn't have any dial fitted.
As for the house slaves under negotiation.... me and my wife have lived with a Synchronome master clock in the hallway and slaves in every room, you get immune to hearing them very quickly. The only time you're aware is when a visitor asks 'what's that noise?'
Let us know how you get on, but I would certainly consider driving any clocks via a relay to minimise contact loading.
Old 4th Dec 2022, 10:45 pm   #8
matthewhouse
matthewhouse's Avatar
Do let us know how you get on! Master clock systems are great fun. I have 5 master clocks here. One of the Synchronomes has been clunking away every 30 seconds since I restored it nearly 3 years ago, it's currently accurate to ~5 seconds per month. It's quite mesmerising watching the mechanism, soon got used to to noise...
matthewhouse is offline
Old 4th Dec 2022, 11:21 pm   #9
Radio_Doctor
Again many thanks. Have now worked out:
The Dictographs are unipolar and move 1 minute forward for each pulse at about 18v.
The older “ship” type clock is bipolar and goes nicely at a much lower voltage. Again moves 1 minute forward each pulse.
The Magneta master system I have pulses it’s slave dial at 30s intervals.
I am assuming these are therefore incompatible with my master clock sadly therefore?
Kneale
Old 10th Dec 2022, 10:33 am   #10
valveaudio
Hello Kneale
Why not make a small 'black box' with a simple divide by 2 circuit and a relay to produce 1 minute intervals to drive the slaves?
If you still need a bench PSU I can lend you one.
Trevor
valveaudio is offline
Old 11th Dec 2022, 11:46 pm   #11
Graham G3ZVT
Graham G3ZVT's Avatar
Yes, don't give up on this just yet!
I'm sure the divide by 2 can be achieved entirely electro-magnetically, perhaps with a couple of Post Office 3000 type relays!
Graham.
G3ZVT
Graham G3ZVT is offline
Old 12th Dec 2022, 7:06 pm   #12
Radio_Doctor
Many thanks again,
Trevor appreciated re: PSU, have already borrowed one. The chap I borrowed it from has sold me modern pulse generator. I bought it anyway as it was cheap enough and may be handy in the future.
I would rather wire these in permanently using the master I have. If either of you were able to circuit advise I’d appreciate it. The PO relays don’t look expensive form what I can see?
Kneale
Old 14th Dec 2022, 11:18 am   #13
Bob_Moss
Bob_Moss's Avatar
It might be worth getting in touch with the Museum of Timekeeping here in Notts. They've got a room full of 'em.
I was so upset that I cried all the way to the chip shop.
Bob_Moss is offline
Old 15th Dec 2022, 9:47 pm   #14
McMurdo
McMurdo's Avatar
will anyone be editing the typo in the title?
Kevin
McMurdo is offline
Old 16th Dec 2022, 7:08 am   #15
Radio Wrangler
Radio Wrangler's Avatar
Default Re: Magneta Master Clock Question
Thanks, Kevin.
Radio Wrangler is offline
