Old 16th Jan 2021, 6:05 pm   #1
spamfritter
spamfritter's Avatar
Default Sanyo VTC 5300 power supply
My trusty VTC 5300 has ceased to function and is completely dead. I have checked the basics (supply fuse, lead etc) and 230 volts appears inside but as I don't have a circuit diagram I am concerned I might create more problems poking around blind. Is there anywhere I can get a circuit diagram and a layout of the PSU at least so I can investigate further. It may be a write off but it's worth investigating first.
spamfritter is offline
Old 16th Jan 2021, 6:13 pm   #2
kevinaston1
Default Re: Sanyo VTC 5300 power supply
Electrotanya have the service manual.
kevinaston1 is offline
Old 16th Jan 2021, 6:25 pm   #3
dj_fivos_sak
Hi there. I had the same or similar problem with my VTC 5350 (missing 15V supply) and the culprit was the switching transistor Q4 (2SB536) on the PW-1 (DC power supply) board. I replaced it with a 2SB506 and the problem was solved. Also check the zener diodes for shorts and check if the two TL494CN ICs are good. I have the full schematic in case you need it.
Regards,
Fivos
ID:	224723   Click image for larger version
Name:	Screenshot 2021-01-16 at 7.23.42 PM.jpg
ID:	224724   Click image for larger version
Name:	Screenshot 2021-01-16 at 7.29.07 PM.jpg
dj_fivos_sak is offline
Old 17th Jan 2021, 7:21 pm   #4
spamfritter
Hi Fivos,
Is there a chance I could get the full PSU diagram ? I do not mind if it is in sections as I can piece it together.
Chris
Old 17th Jan 2021, 10:25 pm   #5
dj_fivos_sak
Hi Chris. I just uploaded the manuals here:
https://drive.google.com/file/d/1yTQ...ew?usp=sharing
You will find the power supply schematics on page 167-168 of the second pdf file (the one that includes the Fisher clones/rebadged models)
Completely ignore pages 136 through 152 and 169-170 as these include schematics for an entirely different machine (a VHS one) by mistake.
I hope this helps.
Fivos
Old 20th Jan 2021, 1:36 pm   #6
spamfritter
Hi Fivos
I managed to download the file --- BIG ! I also manged to extract two of the 3 files OK but the one Sanyo VTC5300P - Fisher VBS7500 etc. will not extract. I get an error message saying there is an error in the zipfile and it can not be extracted. Any ideas ? Running Windows 10.
Chris
Old 20th Jan 2021, 10:03 pm   #7
dj_fivos_sak
Hi Chris. It might be because I zipped the files using macOS. Try this link and let me know if it works:
https://dropmefiles.com/gcwIU
Fivos
Old 22nd Jan 2021, 9:56 pm   #8
spamfritter
Hi again Fivos
I looked at the original files and something called MACOS was attached. I an ot sure what the files at https://dropmefiles.com/gcwIU will do for me.
Chris
Old 23rd Jan 2021, 12:43 am   #9
dj_fivos_sak
Hi again Chris. Just click on the download button at the dropmefiles link and you should receive the "Sanyo VTC 5300P/Fisher VBS-7500/7500S/9900/9900S" pdf file without the need to unzip anything.
Fivos
Old 23rd Jan 2021, 1:33 pm   #10
spamfritter
Hi Fivos
Downloaded successfully. Thanks. Another "lockdown job" I can put on the queue.
Chris
Old 23rd Jan 2021, 2:13 pm   #11
dj_fivos_sak
No worries. Have a look at the schematics and see which voltages are missing. I think you may have lost the 15V standby (always-on) rail as you don't even have a working clock display. If the TL494CN IC has failed, you can find replacements from old ATX computer power supplies. They are very common chips in various switching power supplies.
Fivos
