4th Oct 2022, 2:08 pm | #1 |
Do valve radios use more power?
Im thinking of buying an old Eddystone 830 valve radio, do they use a lot more power than say a Yaesu FRG-7? Im also a bit concerned about the safety aspect, would it be a big job to convert to a more modern/safer power supply?
Steve
Tecsuns PL-310, PL-330, PL-600, PL-880, Yaesu FRG-7700, Kenwood R-1000 and a Yaesu FRG-7 |
4th Oct 2022, 2:19 pm | #2 | |
Re: Do valve radios use more power?
http://eddystoneusergroup.org.uk/Man...3%20Manual.pdf http://www.repeater-builder.com/yvs/...nst-manual.pdf Lawrence. |
4th Oct 2022, 2:22 pm | #3 |
The FRG7 is a solid state receiver and uses around 14W
The 830 uses a lot of valves the filaments alone consuming more than that. Not sure what you think is unsafe about the 830 supply? Cheers Mike T
Invisible airwaves crackle with life or at least they used to Mike T BVWS member. www.cossor.co.uk Last edited by Cobaltblue; 4th Oct 2022 at 2:22 pm. Reason: crossed with Lawrence |
4th Oct 2022, 2:22 pm | #4 |
The user manuals state
FRG7 14VA 830. 85VA So not entirely accurate but that’s similar to a 14watt light bulb and a 85watt light bulb. Apologies Crossed posts.
Frank |
4th Oct 2022, 2:28 pm | #5 |
Valve equipment will always be more power hungry than solid state for an equivalent level of functionality, simply because valves need cathode heaters.
4th Oct 2022, 2:35 pm | #6 |
There might be the odd exception, but in general valve equipment will use more power than solid state equipment of similar performance.
Domestic valve radio receivers tend to be among the worst the low voltage heater supply is generally obtained by a dropper resistance from the mains, thereby wasting most of the energy. A heater transformer would be more economical but adds to the cost and prohibits operation from DC mains, no longer a consideration, but was important decades ago. Consider a 0.15 amp heater chain with five valves each dropping 6.3 volts. Heater wattage is about 5 watts, or from a transformer perhaps 7 watts after losses. With a dropper, the heater consumption will be about 36 watts, plus a couple of watts for the HT. Decades ago this was seldom considered for several reasons, firstly a radio set was expensive, and if you afford one then you could presumably afford the electricity to run it. Secondly other pastimes were limited, reading was popular for both education and entertainment. So 40 watts for a valve radio was less than a 60 watt lamp to read by. And of course a whole family could listen to the radio, still only 40 watts. But four people reading might need several 60 watt lamps, or a centrally placed 150 watt lamp. And for both news and entertainment, listening to the radio was a lot cheaper than a visit to the cinema, which probably involved bus fares as well as the ticket price. |
4th Oct 2022, 2:36 pm | #7 | |
Surely not as safe as a modern rig, I have a Cossor Melody Maker which is in a wooden case so safer I think. Steve
4th Oct 2022, 2:39 pm | #8 |
4th Oct 2022, 2:42 pm | #9 |
As far as I know (could be wrong) all versions of the 830 have a mains transformer so are not live chassis.
I think the 840 is AC/DC Cheers Mike T
4th Oct 2022, 2:43 pm | #10 |
From Eddystone 830 manual, mains consumption is 85VA
Looking at HT and LT currents there is 70.24W but there is transformer and rectifier losses to include, so 85VA in this case likely means 85W. The 830 has full mains transformer isolation, so the chassis is earthed. The FRG-7 manual says it uses 14VA and can run off of internal dry cells. So 14W is believable. So yes, the Eddystone uses much more power than the frog 7. 85/14 = just over six times more. a bit more than still running the FRG-7 and a 60W desk light of old. The FRG-7's valve-stuffed grandad, the RACAL RA117 (block diagram is closer than the RA17 and has silicon rectifiers) is quoted as 100W Racal's attempt at transistorising the RA117 gave us the RA1217 which takes 40VA So that sets the 830 and the FRG-7 in perspective. Me? I have an RA1217, RA1792 and an Eddystone EA12. Had an RA117 some years ago. David
4th Oct 2022, 2:46 pm | #11 |
Thanks guys..
You've put my mind at rest... Are they a good rig for SWL? At least it will keep the loft warm!!! Steve
4th Oct 2022, 2:47 pm | #12 | |
4th Oct 2022, 3:11 pm | #13 |
Via the earth connection as part of the antenna system. They had a far more relaxed attitude to safety etc back in those days!
Also, that may look like a 2-pin connector between the set and the mains cable, but Eddystone used a side-contact as well to connect the earth, so you can wire it with a 3-core mains lead and get mains-earth to chassis connection. David
4th Oct 2022, 4:03 pm | #14 |
Hi
If you are worried about running costs, 85 Watts even at today's 34 pence per kWh still works out at less than 3p per hour. A plasma TV would be two or three times as much In winter, that's all useful heat going into the house so you will save a bit on heating costs. Or give up radio and TV and go down the pub instead. If you drink a pint an hour that's about £3.80 where I live. |
4th Oct 2022, 5:49 pm | #15 |
Mains input of the 830.
Frank |
4th Oct 2022, 6:11 pm | #16 | |
4th Oct 2022, 11:10 pm | #17 | |
If the 830 is in good condition, it was in its day one of the finest receivers you could get, and I bitterly regretted the day when I foolishly parted with mine. I guess some of the modern receivers available today may beat it, but mine was a pleasure to use. Incidentally I remember that they are usually fitted with 2 Jones type plugs on the rear panel, one for accessories and one for external power connections. Check that they are in place, - I believe that there are links in the External power plug which are needed for the set to work. Good luck Dave G0ELJ |
4th Oct 2022, 11:56 pm | #18 |
Hi Steve. This is quite a different thread and you have clearly built up a very interesting collection of [now vintage] radio receivers when there is a general decline in terrestrial broadcasting overall going on around the world. That's in favour of the Internet of course but what comes around?.,. goes around- like vinyl records It's much easier to just switch off everything for everybody including cell phones from an Internet Server and ATM's, as they do in the Far East. That's why people cry when cell phones don't work in a Hurricane in Florida or New Orleans . I think you choose radio sets from an external, intuitive, viewpoint [it's fair enough some people collect sets to simply preserve them, I'm more like that myself ]. In a crisis old technology will still work if you have a good aerial
Best Wishes, Dave W |
5th Oct 2022, 1:42 pm | #19 |
I think the pleasure I get from these old rigs is the tactile experience, tweaking the tuning knob a smidge to the left or right, no DSP or auto tuning, nice as they are, I had a mate round last week, who was the person who got me into SWL, and he was amazed by the pre-selectors etc, I think Ive persuaded him to get a Yaesu FRG-7700. He only has a Realistic DX 394. I enjoy the 80's rigs immensely and I think the joy would only increase with something like an Eddystone. Im still tweaking my long wires every few months...
Steve
