Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Other Discussions > Forum Announcements and Comments
Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval.
Old 3rd Mar 2021, 7:19 pm   #1
Paul Stenning
Administrator
Paul Stenning's Avatar
Default Automotive Posts - Rules and Enforcement
There have been quite a few posts lately trying to stretch boundaries when it comes to vehicles and engines (automotive). Some have been just blatantly against the rules. Moderators have tried to have a lighter touch on these rules recently, but this has simply resulted in more off topic posts.
After discussion amongst the moderators, it has been decided to go back to more strict interpretation of the rules. No asides, no trying to slip mentions of vehicles and engines into otherwise legitimate posts. This will be strictly enforced and if it is too much work to remove the vehicle references the whole post will be deleted.
The following areas of discussion are permitted:
  • In-car entertainment systems.
  • Electro-mechanical vehicle clocks (timepieces, not other vehicle instruments).
  • Vintage automotive test equipment such Crypton and Sun engine analysers, battery chargers, timing lamps etc (but not extending to their use with specific vehicles and not including modern fault code readers etc).
  • Outside broadcast vehicles, TV detector vans, branded dealer vans and similar, but only in relation to the equipment within the vehicles and not the vehicles themselves.
  • Stand-alone sat-nav systems (only in the Modern Technology section and not extended to built-in sat-navs).
  • Electrical polarity modifications to permitted equipment above (but not modifications to the vehicle electrical system).
Anything not covered in this list is not permitted.
When discussing the above permitted areas, it is generally not necessary to mention the specific vehicle. For car radios for example, unless the set is for a specific vehicle only and this fact is relevant to the discussion, then do not mention it at all.
We realise that there are a number of other areas that members may wish to discuss (such as lights, charging systems, immobilisers, keyfobs and entry systems etc). However, we feel that these are too far removed from the purpose of this forum. Instead, we have tried to focus on defining a clear boundary that can be easily understood and enforced.
If a thread requires knowledge of a particular brand and model of vehicle, then the discussion is better had on a forum that specialises in vehicles or vehicle electrical systems. If any members know of suitable well-run vehicle forums, please let one of the moderators know and we will add them here.
As noted above, going forward we will be enforcing this more thoroughly, and offending posts are likely to be drastically edited or just deleted. Persistent offenders may find their ability to post restricted. If your posts keep being removed or edited then please take the hint rather than trying to push things further.
Thank you,
Paul and the mod team.
Paul Stenning
Paul Stenning is offline
Old 6th Mar 2021, 12:50 pm   #2
Default Re: Automotive Posts - Rules and Enforcement
Bump!
Station X is online now
Old 16th Mar 2021, 2:16 pm   #3
Another bump.
Old 17th Mar 2021, 3:17 pm   #4
Bumping yet again.
Discussions about cross ply tyres are completely irrelevant in these forums.
Thank you,
Old 5th Apr 2021, 8:54 am   #5
Bump.
Old 5th Apr 2021, 8:58 am   #6
Thank you,
Bump.
Old 21st Apr 2021, 10:11 am   #7
Bump.
Old 17th Feb 2022, 12:36 pm   #8
Bumping again.
Old 25th Feb 2022, 10:29 am   #9
And again!
Thank you,
Old 2nd May 2022, 9:31 am   #10
Bumped yet again!
Old 27th Jun 2022, 10:42 am   #11
Cobaltblue
Cobaltblue's Avatar
Unfortunately we need to bump this again.
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline
Old 6th Oct 2022, 10:29 am   #12
Cobaltblue
Cobaltblue's Avatar
Unfortunately it's necessary to bump this again.
Please keep Automotive out of your posts.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 12th Dec 2022, 5:30 pm   #13
Bumping again.
This rule is repeatedly being broken by long term forum members who should know better and probably do.
Old 12th Mar 2023, 8:53 am   #14
Cobaltblue
Cobaltblue's Avatar
Having to bump this again.
Please take the time to read this.
Two posts deleted.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 23rd Mar 2023, 1:23 pm   #15
Bumping yet again!!
Old 27th Mar 2023, 11:31 am   #16
Bumping yet again.
One member has already been banned for persistently breaking this rule and others may follow.
Old 31st Mar 2023, 8:46 am   #17
Bumping again after only four days.
One post relating solely to classic car restoration deleted.
Old 11th Apr 2023, 2:37 pm   #18
Bumping this yet again!
Old 28th Apr 2023, 4:41 pm   #19
Bumping this yet again.
If long term members who should know better continue to break this rule we'll have no option other than to ban them.
Old 30th Apr 2023, 12:38 pm   #20
Final warning!
