2nd Apr 2021, 1:12 pm | #1 |
New Member
Can someone identify this tape head please?
I bought a job lot of audio gear and have some of these tape heads. They are 1/8 inch, with no part number; only a printed 'EJ' label on the side. They also have 6 pins which I found rather confusing? The head looks different to all other tape heads I've ever seen too.
I'm sure I'll find some use for them, but not really sure what their function is? Dan |
2nd Apr 2021, 1:41 pm | #2 |
Re: Can someone identify this tape head please?
It looks like stereo with a built in erase function.
2nd Apr 2021, 2:21 pm | #3 |
I think such heads were produced so that a cassette machine could have separate record and play heads.
2nd Apr 2021, 2:50 pm | #4 |
It looks to have ferrite pole pieces for erase and iron for record.
2nd Apr 2021, 3:25 pm | #5 |
There's a similar combined head on Ebay, designated FJ on the underside.
Lawrence. |
2nd Apr 2021, 5:01 pm | #6 |
As it has tape guides on both sides, it's probably for a double side cassette deck. So that the deck can play/record both sides without removing the tape.
Dave
2nd Apr 2021, 5:16 pm | #7 |
But the erase head is full width, which would suggest non standard stereo......
2nd Apr 2021, 6:10 pm | #8 |
It looks like a full width erase and a 2/2 track rec/rep. I'd say it's for a mono high speed duplicator.
2nd Apr 2021, 7:09 pm | #9 |
This one is similar but with only the one tape guide.
5th Apr 2021, 10:24 pm | #10 |
Looks like the head found in Sinclair ZX Microdrive/QL units:-
https://www.oldcomputr.com/wp-conten...drive-head.jpg Last edited by Spec-chum; 5th Apr 2021 at 10:29 pm. Reason: Spelling/verb mistakes |
11th Apr 2021, 11:01 am | #11 | ||
The pole pieces don't look centered relative to the guides to me, although it's hard to tell when seen in perspective (and I should know better than to argue with Ted ). |
11th Apr 2021, 11:59 am | #12 |
I have got an auto reverse machine with a head that turns over.
The head is two parts bonded together and fitted to a sort of turn table. |
11th Apr 2021, 12:08 pm | #13 |
Here is an image of the stereo rec/playback head in my Aiwa WX110 deck. It does not rotate, just fixed in position, apart from moving toward or away from the tape.
Dave
11th Apr 2021, 7:40 pm | #14 |
You've got a point there, Ricard - the perspective is awkward, but a second look indicates the pole pieces are indeed offset in the head face, so yes, it could be conventional stereo...and if a bit of arguing gets us closer to the truth, so be it!
11th Apr 2021, 9:09 pm | #15 |
At the slow cassette tape speed, having the erase head so close to the record head made for cleaner edits on the fly. VCRs with the 'audio dub' feature used a special audio only erase head placed as close as possible to the record head, even bonded to it. As mentioned these were also used in cheaper reversing cassette decks with the rotating head assy. I guess it saved having to use two fixed erase heads. Then there was the Tascam 112R pro reversing cassette deck which used separate erase heads, each occupying a small window , but this was a '3 head' deck. The central rotating head was a record and a play head.
11th Apr 2021, 9:41 pm | #16 | |
11th Apr 2021, 10:17 pm | #17 |
Looking at the picture and perspective - it seems to me that the guide appears to be held on with a screw(s) and is perhaps upside down and can be reversed.
11th Apr 2021, 11:49 pm | #18 |
To my eye, allowing for the distortion due to the angle of the photo, the pole pieces dont look misaligned with the guide and there normally would be no reason for them to be.
There are times when vertically displacing a pole piece from standard is necessary for best capture of a tape recording originally made with a misaligned head, but it's best done of course using a head able to be adjusted vertically independently of the guides. The alignment of the guide relative to the pole pieces can be easily tested by tensioning a section of cassette width tape or leader tape across the head and viewing under magnification. |
12th Apr 2021, 8:49 am | #19 |
Looking at picture 3 it shows on the right hand side a folded over part of the guide bracket that is in the middle of the active part of the head. Although it also looks like the 2 folded parts and guide pieces are too close together for a normal width tape to pass through if this is for a standard cassette recorder.
Further investigation of the actual head is required. |
12th Apr 2021, 10:53 am | #20 |
I think that the folded guide (post 19) is actually a reflection on the shiny head surface. The guides however look to be quite narrow which would suggest a Sinclair style tape reader head. It looks to be only using one half of the pickup as the guides are in the way of the other half. Perhaps another photo showing the head from the side, so that the guides can be seen in relation to the tape path.
Dave
