9th Apr 2021, 7:42 pm | #21 |
Re: HMV Reel to Reel Tape Deck 2210 (actually 2208)
9th Apr 2021, 7:43 pm | #22 |
9th Apr 2021, 7:46 pm | #23 | |
There is no ac voltage rating visible and no class X or Y markings (ac ratings for mains voltage applications and suitable for direct connection across the mains (phase and neutral - class X) or between mains (phase or neutral) and earth (class Y). |
9th Apr 2021, 8:33 pm | #24 | |
It is metallized Polypropylene (MKP) so is good. It has a max DC continuous voltage rating of 1,500V, so is good, these capacitors in this application are often rated at 1,000VDC. Technically this Epcos capacitor is a safety suppression capacitor that normally is used connected across mains voltage but is fine to use here. David |
10th Apr 2021, 6:27 pm | #25 |
It seems that there is a Manual for the HMV 2208 on this site, can anyone show me how to get it.
cheers Spike |
10th Apr 2021, 6:56 pm | #26 |
Hi Spike
Service information is found at the top right of your screen. https://www.service-data.com/search....&search=Search Cheers Mike T
10th Apr 2021, 7:48 pm | #27 | |
cheers Spike |
10th Apr 2021, 8:38 pm | #28 |
Note that you will need two service manuals to cover fully this tape recorder:
The electronic part, which is for the specific HMV model 2208 (including casing parts, specifications, electrical adjustments, brief circuit description, circuit diagram , electrical parts layouts and electrical parts list) and the Thorn DC43 tape deck manual, for the mechanical part (including exploded view diagrams, mechanical parts list, lubrication, mechanical tests and adjustments). Note that many Thorn group brands/models used this combination of DC43 deck and electronics. The differences between models was cosmetic in the main. |
27th Apr 2021, 2:26 pm | #29 | |
Sorry for late question , I work away quite a lot . Any chance you could source a Capacitor as you mentioned in quote, I don't seem to be able to find one. Cheers Spike |
27th Apr 2021, 5:22 pm | #30 |
Replacement Cap
Can anyone recomend a replacement Cap for a "Hunts" 0.003uF 300Vac Capacitor .
Cheers Spike |
27th Apr 2021, 5:48 pm | #31 |
I meant could you give me a equivlent Cap to the original Cap
Spike |
27th Apr 2021, 5:48 pm | #32 |
Re: Replacement Cap
I recently purchased some 3300pf 300v 20% polypropyline capacitors from Farnell on order code 2478390. I got them with a view to using them in my second TMB272, although I've not started that job yet. These capacitors are a rectangular package with both legs coming out underneath. They are not axial round body style and measure approx 12.5mm x 9mm x 4mm, if that helps.
Dave
27th Apr 2021, 5:58 pm | #33 |
Re: Replacement Cap
Farnell UK of Leeds:
https://uk.farnell.com/kemet/pme271m...ial/dp/2913761 or https://uk.farnell.com/panasonic/ecq...-x2/dp/3296010 They may have short leads, which you might have to extend. There will be a delivery charge if your order is of low value. These are currently out of stock: https://uk.farnell.com/kemet/r413f13...90?ost=2478390 Last edited by dazzlevision; 27th Apr 2021 at 6:04 pm. |
27th Apr 2021, 6:07 pm | #34 |
27th Apr 2021, 6:12 pm | #35 |
A bit of information about your tape recorder (HMV brochure dated December 1966 - cost at today's prices - just under £900):
27th Apr 2021, 6:50 pm | #36 |
I would use this capacitor - should be future proof
https://www.cricklewoodelectronics.com/C2K3N3.html |
29th Apr 2021, 1:58 pm | #37 |
Re: Replacement Cap
300v AC will really need a 500V+ DC rating.
Axial lead? https://uk.farnell.com/vishay/mkp183...-pp/dp/2470600 |
29th Apr 2021, 2:18 pm | #38 | |
Re: Replacement Cap
29th Apr 2021, 2:26 pm | #39 |
Re: Replacement Cap
Um, if it's AC rated, where is it located and what's it doing? it may need to have X or Y safety ratings.
29th Apr 2021, 3:08 pm | #40 |
Re: Replacement Cap
Across the primary of the output transformer as referenced in this Thread -
https://www.vintage-radio.net/forum/...d.php?t=178326 David |
