12th Jun 2021, 10:10 am | #1 |
Marconi TF2102 quick question!
Hi!
Just a quick one! Does anybody know why the Marconi TF2102M1 & similar models were provided with no power suppy/mains on/off switch or an indicator lamp? Hum level? Cost? Or were they originally intended to be connected to a control panel that had these? Also, were they an export–only model? The bookwork I found gives the mains lead coding as:– L:– black, N:– blue, E:– green/yellow with earth marker sleeve. Could I replace one of the two output Controls with one having a dp switch fitted without severely impairing the (quoted!) –80 dB hum and noise level? I have one due with a recent purchase of two Levell TG200 non–workers! Chris Williams
It's an enigma, that's what it is! This thing's not fixed because it doesn't want to be fixed! Last edited by Chris55000; 12th Jun 2021 at 10:40 am. |
12th Jun 2021, 11:45 am | #2 |
Re: Marconi TF2102 quick question!
It's a bit of a mystery instrument. See this thread
https://www.vintage-radio.net/forum/...00#post1154700 Might answer a few questions. I note you have the line/neutral colours transposed.
Regards, Richard, BVWS member |
12th Jun 2021, 1:26 pm | #3 |
Hi!
I've read the thread Richard linked to, so I'll go along with the idea of adding a toggle–switch and indicator in the top right–hand corner underneath the "mi" logo! Chris Williams
