13th Jun 2009, 1:07 pm | #1 |
GPO 746 conversion HELP!!???!!
Hello folks...
I am slightly confused re converting my old 746 phone, any help would be appreciated (I am pretty clueless with stuff like this)... I bought a new lead with a couple of components and I have put the supplied resistor between T4 and T5...is this correct? Does it matter which way round it is? I have another component (diode??), supposedly to prevent acoustic shock...I have no idea what I'm supposed to do with this!! Does it go in the earpiece or the phone terminals as per the resistor? Cheers guys Cletus |
13th Jun 2009, 1:45 pm | #2 |
Re: GPO 746 conversion HELP!!???!!
As per the instructions at British Telephones web site, the "rectifier no. 205" should be connected between terminals T1 and T2.
Please note the other instructions there about placement of wires and the addition/removal of straps. Both the resistor and the rectifier (which is really two diodes in opposite polarity) can be connected either way round.
13th Jun 2009, 2:12 pm | #3 |
Cheers Dave
I have wired it as the website suggests: Remove strap T6 - T7 Remove strap T4 - T5 Insert strap T5 - T6 Red wire of line cord to T8 Blue wire of line cord to T6 Insert straps T16 - T17 - T18 - T19 White wire of line cord to T18 Green wire of line cord to T15 Insert a 3.3K resistor between T4 - T5 Insert a Rectifier No. 205 (if needed) between T1 and T2 Unfortunately the phone does not ring, but otherwise functions correctly... Any ideas anyone |
13th Jun 2009, 2:33 pm | #4 | |
13th Jun 2009, 3:41 pm | #5 |
16/17/18/19 are the final (right-hand) four terminals of the bottom row.
CVD's description of the wiring looks correct, and corresponds with the 746 which I have open in front of me. It is worth checking that the ringer is working and wired correctly. The two ends of the coil should be connected to T4 and T16 respectively. With the 'phone disconnected from the line, connect a multimeter set to ohms (if you have one) between these two terminals - there should be a reading in the region of either 1K or 4K. If you get the latter reading, remove the 3.3K resistor and replace it with a strap. Later (or refurbished) 746s were fitted with the higher impedance ringers and do not need the series resistor, which is only added to make a 1K ringer look like 4K to the line. A 4K ringer should still work with the series resistor, but may not pass enough current to ring properly.
13th Jun 2009, 4:37 pm | #6 |
I'll have to get hold of a multimeter and give that a go...
This phone is starting to wind me up now |
13th Jun 2009, 11:26 pm | #7 |
As has been suggested the bell coils may already be ones which are 4K, to prove this replace the resistor on T4-T5 with a strap for the time being and see if the bells now ring - no harm will be done if the bell coils are of 1K impedance whilst trying this. Sometimes the impedance of the bell coils can be seen clearly marked on them, these will be either two 500 Ohm coils or two 2K Ohm coils. I have seen a few "Hard Wired" GPO/BT telephones of this type which have been through their "clean up" process and have had High impedance bell coils fitted before leaving the factory to be put back in to service. Are you trying the telephone connected direct to the master socket or to an extension socket on the same circuit? If using an extension socket it may not be wired correctly; many modern phones only use two wires so will ring even if there is a line reversal or no third "Anti-Tinkle"/Ringing wire connected to the extension socket. Regards Andrew |
14th Jun 2009, 3:54 pm | #8 |
Cheers for the help fellas but I'm still drawing a blank.
Bell coils are 2x500 Ohm... Thanks for the tip Andy, but plugging into the master socket has not made any difference.... I've tried to attach a photo, is the black thing between T1 and T2 the rectifier? Anything look odd? |
14th Jun 2009, 9:23 pm | #9 | |
Out of interest, what happens if you reverse the red and white wires? This will prove whether your line-pair is correct WRT your bell-wire. Another thing to do is to plug your telephone in, take your multimeter on the DC Volts range, and measure between a good, electrical earth (connected to the black multimeter lead) and the following terminals (using the red multimeter lead) of your telephone with the handest on its rest:
Report back with your findings!
Regds, Russell W. B. G4YLI. |
15th Jun 2009, 7:29 am | #10 |
Have alook at post#10 in this thread https://www.vintage-radio.net/forum/...ad.php?t=41547 where I suggest a possible cause..it may not help in your case but it's worth a try given that your wiring appears to be correct.
Dave G1AGK. My perception is my reality! |
15th Jun 2009, 8:57 pm | #11 |
There is a possibility that the Bell coils themselves are open circuit, have you checked them with a meter as suggested in post #5? I have had a few Bell coils go open circuit in 746/706 type phones. Another thing to look out for is the link between the bell coils, is it present and soldered on to the coil tags? Another test you can make is to remove the Blue lead of the line cord and, leaving all other strapping alone, place a strap between T6 - T7; this would then utilize the phones internal ringing capacitor for ringing - don't be tempted to leave the phone wired in this way if strapping like that solves your problem though (if it does solve the problem you have either a faulty line cord, faulty master socket front plate or a polarity reversal as suggested earlier.) Regards Andrew |
15th Jun 2009, 9:44 pm | #12 |
Looking at post #6 and all following posts, I think we can assume that CvanD still does not have a multimeter at his disposal.
Until such a time as the situation changes, it doesn't appear much progress can be made. Perhaps, however, he's taken a meter ohm with him this evening . |
20th Jun 2009, 11:20 am | #13 |
When measuring between T4 and T16 I recorded 3.34K with resistor and 66.6 Ohm when strapped....does this mean I need the resistor or not?
Cheers CVD P.S. Doesn't ring either way |
20th Jun 2009, 1:55 pm | #14 | |
Does your bell-hammer move? Are your magnet pole-pieces fouled by iron filings or dust? Are your wires connected as shown (green not included, but stick it on T15, out of the way). Have you measured the voltages to earth yet, as I suggested earlier?
20th Jun 2009, 2:19 pm | #15 |
Oh, and another thing...
Make sure your plug and lead checks out as per the attached pic.
21st Jun 2009, 8:31 pm | #16 | |
Hi, If you still get these measurements with the T4 - T5 strapping removed, as suggested by Russell, this would indicate that the Bell coils are not open circuit but one (or both) of the coils may have developed shorting turns, which is another possibility. To narrow the fault down further you could try measuring the individual coils direct at their appropriate tags (once again with strap T4 - T5 removed). The readings obtained at each individual coil should be in the region of 500 Ohms. Either way with readings you mentioned above it may be time to think about obtaining a substitute/replacement set of bell coils. Regards Andrew |
9th Nov 2009, 12:28 am | #17 | |
I've learnt a lot from this post, I've spent some time looking at an N-diagram whilst reading everyones advice. Its cleared up a few things for me.
Lets suppose the problem was with CletusVanDamme's master socket (faulty capacitor) or with the line cord and therefore using the phones onboard capacitor resolved the issue. Lets also suppose that all the other phones in his house are relatively modern and therefore even if the master sockets capacitor is bad it doesnt matter as they dont need its capacitor for ringing. You seem to suggest even if this works its not a long term solution: "...don't be tempted to leave the phone wired in this way". Taking into account my theoretical setup, is there the potential to cause damage if the onboard capacitor is used long-term? Ambassador |
9th Nov 2009, 12:55 am | #18 | |
There may be a bit of spurious 'tinging' caused by increased capacity but I wouldn't think any damage would occur. ADSL filters are effectively little master LJUs and all have their own capacitor and bell supply within. Putting several of those on one's extension sockets seems to work OK (apart from the lack of third-wire continuity back the way!) If, as you say, the master LJU capacitor is 'bad' (very unlikely, I would have thought) and so the third wire (term. 3 anti-tinkle / bell supply) is not necessary on the instruments you have installed on your system (ie: those which only have two wires and DTMF tone-dialling) there oughtn't be a problem, as all you've done is shift the master LJU capacitor into your telephone.
9th Nov 2009, 7:11 pm | #19 |
I had this problem on 2 phones . there was a link missing not described in the 'how to' articles. maybe because of the internet filter - This is what I did.
refer to the picture in post 8. The connection with the orange & red wire is 8 (linked with 9) Make sure the cradle switches are down as if the handset is in place. Ring the phone and short with a metal object between 7 and 6. The phone should start ringing. If so please report- then one of the more experienced guys may be able to explain why |
9th Nov 2009, 8:06 pm | #20 |
PWH:
The phone's ringing capacitor (C1 and possibly C2 in parallel if fitted) is connected between T7 and T9. With the modern plug-in system, it becomes redundant and is replaced by one in the master socket or ADSL filter, which is why the strap between T8 and T9 is removed when a phone is "converted", as is the one between T6 and T7. If you needed to leave this/these link(s) in situ, there is possibly something wrong with the wiring in your house, or the blue wire in the line cord Nick. |
