Old 12th Oct 2007, 10:14 pm   #1
ppppenguin
ppppenguin's Avatar
Default Post Office 52A power supply
I have acquired one of these units. Looks like a solidly built unit in a wall mounted metal case. There's a transformer, finned metal rectifier bridge, 2x 2500uf caps and a chunky choke. There's also a 2nd transformer marked 6.5V, 6A which looks like it has been added after manufacture.
I'm guessing that the main supply is 50VDC for telephone kit. What were these units used for?
ppppenguin is offline
Old 12th Oct 2007, 10:18 pm   #2
Sean Williams
Sean Williams's Avatar
Default Re: Post Office 52A power supply
http://web.ukonline.co.uk/freshwater/pugpo1.htm
This ought to tell you everything you need
Looks Fairly useful
Sean
Sean Williams is offline
Old 12th Oct 2007, 10:31 pm   #3
ppppenguin
ppppenguin's Avatar
Sean, thanks for the info.
Old 13th Oct 2007, 12:17 pm   #4
AndiiT
AndiiT's Avatar
Originally Posted by ppppenguin View Post
.....I'm guessing that the main supply is 50VDC for telephone kit. What were these units used for?
The information on Bob Freshwaters site is, as you have probably already realised, relating to a number of different power supplies and their installation/uses.
Looking through that info the 52A power supply was designed for use with the 2/ and 4/ series of PMBX switchboards of the type shown in the following links -
http://www.britishtelephones.com/pmbx2.htm
http://www.britishtelephones.com/pmbx4.htm
Regards
Andrew
AndiiT is offline
