Old 18th Jun 2007, 2:14 pm   #1
bobsterkent
bobsterkent's Avatar
Default Will a loop disconnect phone interfere with broadband?
After 21 happy years in my house still with 'officially' a hard wired phone (2 tone grey 746) but in reality running a 2+4 dollseye and 5 lovely bakelite phones around the house, the drop wire has failed and i have been converted to plug and socket.
now my question is..
if i go to broadband will the pulses from bakelite phones affect it?
bobsterkent is offline
Old 18th Jun 2007, 2:26 pm   #2
ppppenguin
ppppenguin's Avatar
These people say it will work:
http://www.antiquetelephones.abdyantiques.co.uk/faq.htm
but these guys in the USA found otherwise:
http://forums.whirlpool.net.au/forum...fm/376425.html
I just tried it by switching my desk phone to LD and the BB stayed working.
ppppenguin is offline
Old 18th Jun 2007, 3:21 pm   #3
bobsterkent
Default Re: Will a loop disconnect phone interfere with broadband?
Oh goody, i can put it all back again then! Its only been a day but i'm missing a bakelite phone by my armchair already!
Old 18th Jun 2007, 6:27 pm   #4
Nickthedentist
Nickthedentist's Avatar
It works fine for me too - though thinking about it, I'm surprised that it does
I have several 200/300/700 series phones on my line, along with a BT Diverse cordless system plus broadband. Everything runs harmoniously (though because of the way the plug-in microfilters work, there is some bell tinkle on dialing).
BTW, do BT still charge you to rent your 746? If so, why not give it back and pick up an identical one for about £1 at any car boot sale?
Nick.
Nickthedentist is offline
Old 18th Jun 2007, 6:46 pm   #5
paulsherwin
paulsherwin's Avatar
I suspect you'll get a bad data packet with each pulse, but this won't be obvious in normal use as it will just be resent. You should see the error count going up in the router though.
Paul
paulsherwin is offline
Old 18th Jun 2007, 7:10 pm   #6
Sam
Sam's Avatar
My Ericophon will dial out, ring (OK, buzz), and answer OK on my line with Broadband.
Sam
Can he lead a Normal life, Doctor?
No, he will be ... an Engineer.
Sam is offline
Old 18th Jun 2007, 10:08 pm   #7
plumbweiss
If you pick up a cheap 2nd hand PABX switch such as the Southwestern Bell Omicron (used to be stocked by RS) these will accept LD and automatically retransmit it as MF to the exchange.
plumbweiss is offline
Old 18th Jun 2007, 10:23 pm   #8
bobsterkent
I have been renting the 746 up till last week as that way they wouldn't come and convert me to plug and socket but now i have been done then i'll get broadband and then re-install the switchboard and carry on again. I know all about the ren etc and so i'll put in the resistor and i had already converted all the 300's to a modern mic. The engineer did think i was the last on my exchange that was still hard wired and thus still on a rotary dial
Old 18th Jun 2007, 10:41 pm   #9
Nickthedentist
There's no real reason you shouldn't "convert" back to hard-wired if you prefer...
You could leave their new NTE5 master socket in situ, then simply connect all of your old system, as-is, to the "subsciriber's extension wiring" terminals (2 and 5) on the rear of the removable faceplate. Electrically, the set-up would be identical to what you had before. See here: http://www.adslnation.com/support/extensions.php
If you got broadband, just replace the front of the master socket with one of these: http://cpc.farnell.com/jsp/Office+Su...sp?sku=TE04368
It takes 5 mins to install, then all your old wiring will have the broadband signal filtered out. And it's BT Approved
Nick.
Old 18th Jun 2007, 10:51 pm   #10
Sean Williams
Sean Williams's Avatar
No Problems here, well other than having too many blasted phones ringing......
746, two homehub phones, one cordless, and the fax machine........
Sean Williams is offline
Old 19th Jun 2007, 7:36 am   #11
ppppenguin
ppppenguin's Avatar
Nick's advice about using a splitter faceplate is good. Saves having microfilters dangling everywhere and will give best ADSL speed if you have a marginal line. I blagged mine off the BT guy who came to remove my Home Highway. A few years ago they were rare items now they're widely available. I googled "adsl splitter faceplate" and loads of hits including:
http://www.solwise.co.uk/adsl_splitters.htm
Old 19th Jun 2007, 8:24 am   #12
Tazman1966
Tazman1966's Avatar
Mornin'
I removed the microfilters to see if the bell tinkling whilst dialing on my two 746 phones would stop and sure enough it did with no noticaeble effect on the internet. You do occasionally get some hissing on the phones.
All the very best,
Tas
Tazman1966 is offline
Old 19th Jun 2007, 8:30 am   #13
ppppenguin
ppppenguin's Avatar
Not recommended. You are probably close to the exchange and the modem/router isn't having to work too hard to give you decent speeds. Have you checked the sync speeds and error rates?
Old 19th Jun 2007, 8:42 am   #14
chipp1968
chipp1968's Avatar
I have a dial 30s phone connected and use broadband in the same socket plus a wireless phone ! but it all works ok . they give you a plug in filter to run the phone and bb from and everythings plugged into that .very
Heath Robinson
chipp1968 is offline
Old 19th Jun 2007, 9:29 pm   #15
Tim
Tim's Avatar
My 50's Tele 332 doesn't affect my BB at all.
Tim is offline
