Old 1st Nov 2019, 11:36 pm   #1
BenHoper
Default Telephone Set "F" MK II questions
I have a pair of Set F Mk II, one TMC, one GEC which I'm trying to get operational. They both ring from one to the other - except one has lost its clanger. Both ear pieces seem to work, but I can only speak from one to the other. So I want to check out one of the handset microphones.
Q.1. I've wired Earth to Earth, and L1 to L1, is this right?
Q2. How do you get the microphone out of the handset? I can't seem to unscrew it. There is a little play then it stops. I can't pull it. Don't want to break it after 75 years.
Thanks,
Ben
BenHoper is offline
Old 2nd Nov 2019, 6:04 am   #2
TonyDuell
Default Re: Telephone Set "F" MK II questions
Thanks,
Ben
I don't know if this applies to your telephone, but on a lot of them the mouthpiece is fitted with a locking bayonet fixing.
Look for a small hole in the side of the mouthpiece, on the side pointing towards the earpiece. Put a small tool in there and press to release the catch, hold the tool in, then turn the mouthpiece anticlockwise and it will come off.
TonyDuell is offline
Old 2nd Nov 2019, 11:06 am   #3
russell_w_b
russell_w_b's Avatar
Have you tried swapping the handsets over to see if the fault carries with the handset? They just unplug on the four-pin jack.
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline
Old 2nd Nov 2019, 11:19 am   #4
BenHoper
Thank you Tony. That works a treat. I had tried that but didn't push hard enough. I'll do some test now. Should have said its a YA2636 handset.
Russel, yes, tried that and it does go with the handset. More tests now!
BenHoper is offline
Old 2nd Nov 2019, 11:54 am   #5
Dave Moll
Dave Moll's Avatar
It is also worth checking the health of the battery in the one whose transmitter (microphone) isn't working - though first try Russell's suggestion of swapping handsets first to confirm whether the problem lies with the handset or the main unit.
Do your units have buzzer units? This can be established by checking whether the plug-in unit in the right-hand lobe of the body is an enclosed unit with two knobs on top (buzzer) or an open unit containing just an induction coil (no buzzer).
If one or both have buzzers, try pressing the button on the front right-hand side to the left of the handset plug and checking whether the buzz is audible in the other handset. This will have the dual effect of checking the battery health of the initiating set and that the receiver in the other set is operational. If only one has a buzzer, then try swapping the handsets and repeating to check the second receiver.
edit: (presumably owing to need for moderator approval on initial posts) Ben's second post hadn't appeared when I made my post, so forget battery checks. It is still worth checking whether the problem lies with the transmitter or receiver.
In the absence of a buzzer, the receiver can be checked by connecting a low-voltage battery across the inner two prongs of the handset plug - with the handset unplugged from the main unit.
Dave Moll is offline
Old 2nd Nov 2019, 8:18 pm   #6
dagskarlsen
dagskarlsen's Avatar
Hi, I had one of those with a defect transmitter capsule. when you think about the age, that is not strange. I took a carbon transmitter from a newer phone, and soldered 2 wires on it and used that. I have now sold that one since I could get a better one, and did not have any need for 2.
dagskarlsen is offline
Old 2nd Nov 2019, 10:34 pm   #7
BenHoper
Thank you Dave and Dags
It's all working! I cleaned up the connections and tightened screws, checked the capsules, and now it works just fine. Using 2 x AA on each phone.
It's a non-buzzer type.
Just need to find a couple of spares now. I'll post in the wanted section.
As to restoring some more:
Would you polish the bells? Or would that destroy the aged look? Do people care?
Thanks for all your help on this, my first visit to this forum.
Regards,
Ben
BenHoper is offline
Old 3rd Nov 2019, 8:15 pm   #8
ex seismic
The bells would not have been polished in field service, not very tactical! But in the days of National Service, if it moves salute it, if it doesn't paint or polish it.
ex seismic is offline
Old 3rd Nov 2019, 9:30 pm   #9
russell_w_b
The type 'F' was not a 'battlefield' telephone as such but would've been used in field-offices and not normally used beyond Divisional-HQ, so perhaps the shininess that may catch the enemy's eye would be masked by keeping the telephone part-withdrawn from the wooden box as far as the handset-cradle. The Type 'D's with their PTT switches and 'work-in-any-position' capability would be on the front line.
Any 'F's I have are chrome-gonged, with rather a rough matte finish on them. I tried polishing one as a kid, when I had a couple (£1.50 each I paid with new-fangled Decimal Currency!) but it didn't make much difference. I didn't have a buffing wheel, though.
Regds,
Russell W. B.
G4YLI.
Old 6th Nov 2019, 11:03 pm   #10
BenHoper
Thanks for the input, I'll give them a tidy and post some pics.
Regards to all,
Ben
BenHoper is offline
Old 7th Nov 2019, 11:19 pm   #11
Pellseinydd
<snip>.
Also we used Tele L and later Tele J with the 'Switchboard Magneto 10 Line' introduced during WW2 - the Tele D Mk V being buzzer calling was used with the earlier 'Switchboard, Universal Call 10 Line'.
The Tele F was used to below Divisional Level. There was a metal plate with curled up 'sides' and a webbing strap used to clamp the Tele F on a flat surface in vehicles - it was used without the wooden box in that case.
Ian J
one-time Lt. R.Signals, serving with none other than the Earl Kitchener of Khartoum it was that long ago !
Pellseinydd is offline
Old 12th Nov 2019, 10:37 pm   #12
Oldcodger
Thanks,
Ben
I seem to remember my old mentor showing me the "easy " way to release the lock- use one side of a pair of long nosed pliers ( AKA in PO terms 81's).
Oldcodger is offline
