28th Sep 2017, 6:51 pm | #1 |
"Genie" telephone
I have recently acquired a "Genie" telephone (the 'phone that looks like Aladdin's lamp) with a rather odd fault, in that it rings on an incoming call, but fails to make a loop. Although the ringing stops when the handset is lifted, the calling telephone continues to receive ringing tone, and the ringing resumes if the handset is replaced.
Because it fails to make a loop, then handset is dead when lifted, whether or not there is an incoming call. The problem doesn't appear to be with the gravity switch, which has two pairs of contacts, both of which are closed on-hook and open off-hook. Any thoughts on where to look next would be appreciated.
28th Sep 2017, 7:45 pm | #2 |
Re: "Genie" telephone
I assume the 2 contacts on the gravity switch are for line switching and anti-tinkle.
The latter will short-circuit the internal bell/ringer which explains why it stops ringing when you lift the handset. But it will not complete a DC loop across the line, so that's why it doesn't cause the exchange to remove the ringing voltage, etc. First thing to check is the line cord. If the pin 2 wire (red) is open-circuit then the phone will behave like that as you only need pin 3 (blue) and pin 5 (white) for the ringer and anti-tinkle switch. If that's good, then you will have to trace through all the wiring in the telephone to see just how the DC loop is completed and why it isn't working in this case. |
28th Sep 2017, 10:25 pm | #3 |
Thanks. I've checked all four line cord wires and confirmed continuity on each through to the connector on the circuit board; also confirmed the presence of 50VDC between red and white at that connector when plugged in. It looks, therefore, as though I'm faced with following the tracks as you suggest.
I'll report back with any progress.
29th Sep 2017, 9:40 am | #4 |
Our very first 'inphone' when I lived with the parents. It was expensive. Ours was in the peach colour (still got it) and stamped 'Made by AP Besson' at the bottom. It was one of those things that Mum 'just had to have'.
Being an earlier one there was no redial, just a couple of blank buttons. The place where the redial button was later installed still worked if you were trying an engaged line, but it forgot the number if you went back to it a few minutes later.
Kevin |
30th Sep 2017, 8:26 am | #5 |
Hi, I do not have mine in the house, so I can not test it , but mine had an odd configuration on the RJ jack in the phone. I can not remember if it had 2 wires going in, and 2 to the ringer, or r wires + 1 to the ringer. Mine was made in Norway according to paper sticker under the phone.
dsk |
6th Oct 2017, 7:48 am | #6 |
I did think to have a go at tracing out the circuit, as there's not too much in the way of discrete components outside the three chips. The problem I've encountered, though, is that I can only find datasheets for two of the chips. The one I can't find is labelled:
MEDL 8721 ZMA522PO Presumably, this is a custom chip. Would that "PO" at the end signify "Post Office" by any chance?
6th Oct 2017, 8:01 am | #7 |
Not sure about the PO but MEDL is the manufacturer (Marconi? Now Dynex?), and 8721 the date code so presumbaly its part number is the ZMA... bit.
6th Oct 2017, 11:48 am | #8 |
I came across an MEDL chip in a Tribune telephone andalso couldn't find data on it. But as the other 2 ICs were Texas Instruments (and I have the appropriate databook on the kitchen shelf...) I quickly found those were the speech circuit ('hybrid', replaces the induction coil) and the ringer. Since the unknown IC linked to the keypad, I deduced it ws the dialer.
6th Oct 2017, 1:21 pm | #9 |
Yes, I tried a search on that as well and came up with nothing relevant.
6th Oct 2017, 1:24 pm | #10 |
I'm in the library at the moment, so I'll check when I get home, but I think one of the other chips was the dialler.
6th Oct 2017, 7:46 pm | #11 |
Can you post the numbers of the other 2 ICs so we can see what functions they perform, please
7th Oct 2017, 6:50 am | #12 |
MC34017 and TEA1061. As I say, I have data sheets for both of these. The latter is described as "versatile telephone transmission circuits with dialler interface".
7th Oct 2017, 7:50 am | #13 | |
I do wonder sometimes about the mindset of those who come up with company names.
7th Oct 2017, 10:22 am | #14 |
Ah, thanks Chris.
And no, I don't think the "PO" refers to Post Office, as everything was well and truly BT'd by 1987. |
7th Oct 2017, 12:56 pm | #15 |
The TEA1061 is the speech circuit (the replacement for the induction coil), the comment about the 'dialer interface' means you can link a dialer chip to it (it has a pin to inject the DTMF signal). The MC34017 is a ringer. So that means that (as in the Tribune I was working on) the MEDL IC is the dialer.
Is there a discrete transistor circuit acting as a line switch hung off the dialer chip? If the telephone supports pulse dialing then that is likely. If that's failed the telephone won't loop the line. |
7th Oct 2017, 6:58 pm | #16 |
Ah, now I understand, "dialler interface" means that it interfaces with the dialler rather than being the dialler itself. I'll check out the wiring round the MEDL chip, but if this means the chip's blown, it doesn't sound hopeful.
By the way, I had meant to say that I had identtified the MC34017 as the tone ringer. My previous reply was typed in a hurry, as I had to head off early this morning.
14th Oct 2017, 6:19 pm | #17 |
I have one of these. I took it apart in order to take some components, and found this forum/thread when I was searching for MDEL 8721 ZMA 522.
Dave, if you would like it [the whole phone or the chip if I can get it off]? I'd just need postage. -John |
14th Oct 2017, 8:12 pm | #18 |
PM sent.
13th Feb 2018, 5:50 pm | #19 |
I've just got a UK Genie (Telephone SR8023, it has the LR button) and it's in bits on the bench. More details when I have figured out more.
The gravity switch has 6 pins. Seems to be one break (when off-hook) contact that is not used and 2 make contacts that are are. The latter would seem to be to connect the telephone circuit to the line and for anti-tinkle as expected. A word of warning, don't take the gravity switch apart for fun. It's a curious design with spring contacts going over a plastic rocking roller with internal metal contacts. Getting it back together is not at all easy. |
13th Feb 2018, 9:28 pm | #20 | |
