19th Oct 2007, 12:50 pm | #1 |
Use of GPO 2mf capacitor C1?
I picked up a big black flat 12x12x1cm capacitor stamped G.P.O. 2mf C1. It measures 2.5mf but not sure of voltage.
What would it have come from and I guess it's not the first capacitor the GPO used! |
19th Oct 2007, 1:07 pm | #2 |
Re: Use of GPO 2mf capacitor C1?
I would imagine that it was the capacitor in series with a bell - to block the DC. With modern PST wiring this is superseded by the 1.8µF in the master socket.
19th Oct 2007, 1:47 pm | #3 |
Probably 250 volt DC
19th Oct 2007, 5:19 pm | #4 | |
Hi, Dave's guess is most probably correct, some Switchboards and early Bellsets used a 2uF (mF) capacitor in the bell circuit. Remember that the "bell" capacitor (whether in the phone/switchboard/master socket etc.) is sometimes also employed as part of the Anti-sidetone balancing network. Modern day equipment (2-wire phones, ADSL filters, dial up modems etc.) use a 1.8uF capacitor as Dave mentions. Voltage wise 250V AC seems a reasonable guess, ringing current is 75 Volts AC at 25 Hertz. Regards Andrew |
19th Oct 2007, 6:06 pm | #5 | |
The capacitor in question was sometimes found on the earlier type 336 telephones. Mine has a cylindrical unit fitted, clearly marked as 200V DC working. The 2uF capacitor would be the bell capacitor, with a combined 0.1uF capacitor across the carbon inst microphone to by-pass RF pick-up.
Regds, Russell W. B. G4YLI. |
19th Oct 2007, 6:12 pm | #6 |
Just had a peep inside my British Ericsson type N1071 Bakelite wall instrument, and it is fitted with a grey, square section dual capacitor (2uF and 0.1uF) and is clearly stamped: 200V DC WKG.
19th Oct 2007, 6:59 pm | #7 |
I acquired this capacitor from a GPO engineer about 40 years ago. 3 caps 2uF, 0.5uF & 0.3uf in series rated at 200v. Sealed in a metal case 6.3cm x 5.5cm x 2.5cm and made by Sprague part number CA-355. No idea what it would have been used for but I guess it would have been a GPO custom part.
Keith |
