Old 4th Nov 2019, 6:14 pm   #41
G6Tanuki
G6Tanuki's Avatar
Default Re: BHS Branded Metamec Battery Clock
Originally Posted by Paul Stenning View Post
The battery contacts just fixed with screws into plastic and pressing onto the PCB tracks does look like an area that could become loose and suffer with corrosion over the years. If you can bypass that with soldered connections to existing contacts or new battery holder they may well help.
Yes - poor electrical contact in such low-current situations is a real problem: I've got a 15-year-old "Radio-controlled" (DCF77) shack clock here which started playing up - the sprung battery-contacts were attached to the PCB by small tubular rivets. Clearly the contact between spring-and-rivet or rivet-and-PCB had become flaky because a gentle tap with a punch-and-toffee-hammer(!) on each rivet solved the problem.
[Soldering wasn't really an option, the springy contacts being that kind of plated-steel which never takes solder well]
G6Tanuki is offline
Old 12th Nov 2020, 2:47 pm   #42
paulsherwin
paulsherwin's Avatar
Thread reopened by request.
paulsherwin is offline
Old 24th Nov 2020, 11:37 am   #43
PsychMan
PsychMan's Avatar
Well, after many times looking at this movement and trying to repair it (the fault wasn’t the battery connectors). I was hoping to post how I permanently fixed this clock....But, unfortunately my repair yet again didn’t work.
I’ve had this thing off the wall too many times to count, and the last time it went back up it must not have sat right on the screw it was hanging from.
The clock subsequently managed fall off the wall (suicide perhaps?). The plastic casing seemed to have gone very brittle with age, and shattered into many small pieces making a decent repair impossible. The icing on the cake was the glass on the face also cracked in the process....
Very reluctantly, the remains of the clock have now gone in the bin, RIP
My other half however is delighted, because I will not be pouring hours more of my time into a cheap plastic clock that was never intended to last anything near the 42 years that it has. I don’t like giving up on old things, but sometimes you have to know when to throw the towel in!
Adam
PsychMan is offline
Old 24th Nov 2020, 11:59 am   #44
paulsherwin
Very sad after all that effort, but as you say, sometimes you just have to walk away.
Old 24th Nov 2020, 12:16 pm   #45
McMurdo
McMurdo's Avatar
that's a shame. At least it had a good innings and wasn't chucked on a fashion whim.
Kevin
McMurdo is offline
Old 24th Nov 2020, 6:19 pm   #46
stacman
I wonder if the replacement will last 40 years plus....
stacman is offline
Old 25th Nov 2020, 10:52 am   #47
PsychMan
PsychMan's Avatar
Indeed, well I doubt it, Not the movement anyway! 42 years for a plastic quartz movement that ran dry in a kitchen environment is impressive stuff.
This is what I bought to replace it:
https://www.rexlondon.com/1950s-ivor...BoC4dwQAvD_BwE
I dont have high hopes of quality, but it has a nice sweeping second hand, and apparently silent movement. If the movement claps out, assuming the rest is decent enough, I'll stick another movement in. I like old clocks but thought I'd try something new and "practical" for kitchen
I have other old clocks around the house that are better deserving of attention - including a family heirloom victorian dual fusee clock
Adam
PsychMan is offline
