Hints, Tips and Solutions (Do NOT post requests for help here) If you have any useful general hints and tips for vintage technology repair and restoration, please share them here. PLEASE DO NOT POST REQUESTS FOR HELP HERE! |
10th Jun 2021, 9:56 pm | #1 |
Method for colouring and texturing epoxy resin
I found by experiment that I could tint normally clear epoxy resin very easily using laser toner powder (laser printer).
I needed to achieve a dark anthracite colour to fill in a chipped surface. I am aware that black epoxy is available but did not have any nor did I want to purchase a tube especially for this very small job. I used black toner powder, added while mixing the clear adhesive and hardener together. While setting I noticed that the result was going to end up too glossy compared to the base material so while it was still tacky I dusted the surface with more toner giving a matt look. The results were surprisingly good. I have not tried with magenta, blue or yellow toner or any blending of these. Best Regards Chris |
11th Jun 2021, 12:08 pm | #2 |
Re: Method for colouring and texturing epoxy resin
When I was a student, in the lab at STC where I did work experience, every bench had a small tool box which included a pack of Araldite and a small jar of Titanium Oxide powder that they used to mix with the Araldite where a white finish was required. I have coloured Araldite brown to fix some earthenware plant pots by grinding a piece of broken pot in my wife's kitchen pestle and mortar to a very fine powder.
14th Jun 2021, 5:34 pm | #3 |
I wonder how to achieve a brown bakelite colour and whether filing/grinding bakelite to mix with it would achieve that? I guess this has been done effectively.
19th Jun 2021, 1:07 pm | #4 |
I think you might need to be careful where you get the old Bakelite from, as some used asbestos fibres as the filler and if ground up they may present a health hazard.
Chris Wood BVWS Member |
28th Aug 2021, 9:59 pm | #5 |
Today I was repairing a garden water feature clay pot. I used Araldite rapid. I coloured it with a couple of drops of Bolgers spirit based wood dye. It mixed easily and the mixture cured as normal. I was quite pleased with the result, more for thoughts on future use. Colin
28th Aug 2021, 10:47 pm | #6 | |
B
29th Aug 2021, 2:01 am | #7 |
Where I live you can dig up clay that is a good match for plant pot repairs once dries and mixed with epoxy.
26th Sep 2021, 7:04 pm | #8 |
I found cheap watercolour paints crushed up work well and the range of colours are easier to get close.
26th Sep 2021, 9:48 pm | #9 |
I've seen methods of colouring PVC using wax dyes which would seem to suggest they would mix well with epoxy. Since these dyes are all available in a full pantone range (many suppliers will make a mix to your requirement) the options seem endless.
Getting hold of a CMYKW selection (cyan, magenta, yellow, black and white) should allow anyone to mix 'any colour' on spec. You can also get 'glitter' in gold/silver - almost powder-like - to make a metallic finish. |
