4th Jul 2011, 8:11 am | #21 |
Re: Is the mains 'earth' good enough?
All agrees. Pipe Earth bonds is purely for safety of anyone touching fittings. I think what ppppenguin says is true, try it. Just ensure the that if you are using mains earth it's via the 3 core mains flex and leakage is within limits.
4th Jul 2011, 10:22 am | #22 |
Providing that the earth continuity on your property's internal electrical wiring is ok then it should be ok to use 3 core mains cable and only connect the earth wire of the cable into the earth pin of the plug, just make sure your plug does not have one of those plastic earth pins that are found on plugs for double insulated appliances.
You can test earth continuity by using a multimeter and measuring the continuity between the earth of the socket and a radiator water pipe that should ideally be connected to the ground of the mains, you should hear the continuity beep on the multimeter and the resistance should read 0 ohms. |
4th Jul 2011, 11:31 am | #23 | |
As others have stated, the earth in the mains flex/plug/socket etc. is a Protective Earth or PE, it is there to protect You from a lethal electric shock in the event of a fault. If you add an earth rod solely to help the radio work better/better reception etc. then this will be a Functional Earth or FE, this is sometimes called a 'clean earth', and should be kept totally seperate from the PE, as this has nothing to do with protecting you from electric shock, it is there to enable the device to function as intended. They are two completely different things In the current Regs. a PE should be sleeved in the familiar Green/Yellow stripe, and the FE should be coloured Cream, some of you will have seen this on an RCBO 'earth lead'. Also the rules are very strict on PE's (and rightly so!), where as there are next to none for FE (except follow the manufacturers instructions) Some of the confusion arises, because manufacturers have sometimes 'combined' the functions of Both the PE and FE, into just a single conductor, ie. the CPC (Circuit Protective Conductor) in the mains flex, for both cost saving and convenience to the user. Also the fact almost nobody uses 'Cream cable', and everybody just uses the 'common garden' Green/Yellow for FE aswell! It also doesn't help that the wiring regs have changed many times over the years, and obviously on this forum we are using long since 'obsolete' equipment (and I mean this in the nicest possible way). Needless to say that the Protective part takes priority over the Functional part EVERY TIME. Cheers, Baz
I don't suffer from Insanity. I enjoy every minute of it. |
4th Jul 2011, 11:57 am | #24 |
Thankyou Baz, that's a very good summary without getting too technical, which is what I was trying to avoid.
Rob.
We have done so much, for so long, with so little, we are now qualified to do anything with nothing. |
4th Jul 2011, 3:05 pm | #25 |
Brilliant Red to black / Baz!
