23rd Jul 2020, 3:40 am | #1 |
Sony Betamax C7 no video
I'm trying to get an old Sony betamax SL-C7UB to work again after being in storage for 30 year or something. I managed to get tapes to eject, rewind, fast-forward and play after some initial problems with the mechanism sticking. I just can't get any video output. The test video and audio signal works fine and audio from tapes works but only via the phono out not the aerial output. I have tried using a composite video cable but this doesn't work either. I get no video of any kind no static or anything on both aerial and composite output. Anyone have any idea what might be wrong? |
23rd Jul 2020, 11:22 pm | #2 |
Re: Sony Betamax C7 no video
Do you get any signal passthrough (E-E mode) from the tuner or if you plug something into the video input of the C7?
24th Jul 2020, 5:53 pm | #3 |
E-E works, so does video input.
I think the problem is being masked by the fact that modern TVs instead of showing static when un-tuned or when there is no signal only show a black screen. I noticed I could see a brief glimpse of something between switching the test signal from on to off when playing a tape. It seems the video output is so bad the tv considers it not an actual signal so shows only a blank screen. I tried using a different TV and I was able to get a picture briefly So it seems the actual problem isn't that there is no video output but just the video output is extremely bad. |
25th Jul 2020, 12:33 pm | #4 |
Possibly a silly quation, but are the heads clean? Might be worth seeing if there's anything in pause or picture search when less muting is applied.
25th Jul 2020, 5:16 pm | #5 |
Always use an analog TV/monitor when testing this kind of equipment. Most modern sets treat unstable signals as unusable and therefore they just display a black/blue screen instead. As Glyn pointed out, make sure the entire tape path is clean. Cleaning the heads on a machine that sat unused for 30 years is mandatory. The C5/6/7 machines are known for their failing capacitors in the servo circuit. That would cause the head drum and/or capstan speed to unlock and in that case there would be no stable video signal coming out from the machine.
Regards, Fivos |
25th Jul 2020, 6:02 pm | #6 |
When cleaning the heads make sure that that you also clean the audio control head assembly.
If you have no control pulse it mutes the video on these vcrs. Dave |
27th Jul 2020, 12:03 am | #7 |
Check too the RF Envelope first.
Libratron |
27th Jul 2020, 10:31 am | #8 |
True - that's why it's best to use an old TV and try picture search to see if there's any picture visible.
