9th Jul 2020, 11:06 am | #1 |
Ferguson TX 37100
I’ve got Ferguson tx37100 worked fine but now will not tune into freeview box can anyone show me where the Turner is inside tv and is it easy to change might have a replacement thanks mike
9th Jul 2020, 12:25 pm | #2 |
Re: Ferguson TX 37100
It’s the big silver box with the wire to the aerial socket running from it.
Possibly a Mullard U321. Easy to change if you can solder properly. But check its supply voltage and the variable tuning voltage first. Presume you found the tuning presets under the flap at the bottom of the speaker grille? |
9th Jul 2020, 1:15 pm | #3 |
Yeah I did it seemed to be glued in tv was working ok but now not picking up anything well there is a snowy black n white picture fuzzy and sound wonder if it could be freeview box
11th Jul 2020, 10:08 am | #4 |
Well, it could, so I'd check the box first with another TV to be sure. Have you replaced the tuner? It's probably a Thorn type which is similar to an ELC 1043/05.
