11th Jul 2020, 6:20 pm | #81 |
Re: Help with a Philips Anubis AAC Set
Strange name for a set. As Anubis was the Egyptian god of death and mummification, perhaps it's trying to tell you something
Roger |
11th Jul 2020, 9:25 pm | #82 |
They (Philips) went through phases of naming chassis. They chose an Egyptian god as they are probably less well-known than the Greek ones. I think they used some Greek god names for a range of VCR decks (Apollo springs to mind) and they also used some names from the Phonetic Alaphabet (Charley, Delta, Echo, Juliet and there might have been a Queen as well).
11th Jul 2020, 10:30 pm | #83 |
they also went with odd letters/numbers - GR2.2, MD1.2E, L01.2E, L6.1, A7H etc.
Could start a thread with the odd names/numbers Manufacturers used for their chassis Ive bought the Anubis AAC set too so once that arrives my set will be fully restored.
Cheers, Luke |
12th Jul 2020, 9:31 pm | #84 | |
I think the Anubis A chassis was the last or close to the last consumer chassis to be designed and produced in Monza. After that they switched to the L series (likely L for Low End, with the number referring to the year of introduction - L6 for 1996, L01 for 2001, etc.) Which I think were mostly designed in France. I don't know of any other Philips TV chassis with a "real" name besides Anubis. They did use acronyms a lot, however. G or GR for global range. CT for Colour TV (CTX was Dutch/Singporean, all other CT. chassis were Spanish). MD for Mid Range. FL for Feature Line, etc. |
15th Jul 2020, 12:52 pm | #85 |
I have been moving stuff round my workshop and think I have located the Anuibis set I mentioned. Will try and take a few pictures of it when I get up close!
Regards, Ben. |
15th Jul 2020, 10:31 pm | #86 | |
19th Jul 2020, 10:27 pm | #87 |
Shes ALIVE!!
Replacement Chassis arrived, fitted and working perfect, Finally this story is at an end, Its old board I'll keep as a parts donor for any future repairs that might be necessary.
Cheers, Luke |
12th Aug 2020, 12:43 am | #88 |
Replacment Chassis New Fault...
all I know is something on the 9v sound ground shorted and i dont know what component/s have failed but the fault is intresting. when the short happened the set went Dead, just a slight whimper from the smps transformer, suspected the the 630mA fuse (1540), checked and it was a dud, replaced it and the set came back to life and i just assumed everything was fine. not so.... last night i discovered the Scart and Front AV sockets no longer work though the screen goes Black on Programe 0 like it normally does when its waiting for a signal . No Picture or Audio when Scart or Front AV devices connected. Tuner works and had a VCR connected, Played a tape and the picture is fine but the sound is distorted and low (kinda grumbeled and slightly echoy) but changing the station to AV (0) the sound from the video comes through crystal clear but no picture. Theres must be some kind of switching problem or missing voltage somewhere, the AV station is being fed crystal clear audio from the tuner which is odd but when av devices connected nothing happens. and on the actual tuned station the audio is terrible. included the power supply diagram showing the fuse that blew and also the circuit for Scart and IF Anyone any suggestions, always appreciate all the help you guys give.
Cheers, Luke |
