7th Jul 2022, 8:14 am | #41 |
Re: EAR De-Luxe Record Player
Use your meter to check for an obvious short circuit across the HT supply. The resistance here should be infinite, but it'll initially show as low until the capacitors are charged by the meter. This charge will be harmless as the meter's voltage is low. Unplug the motor or remove a valve first to avoid shunt effects.
Opening the capacitor can would effectively destroy it, so there's no point in doing it unless you intend to restuff it. Much easier to fit new caps on a tag strip. Personally after replacing the rectifiers and resistor I'd power up the player via a Variac or test lamp whilst monitoring the HT voltage. Or I'd use my capacitor reformer to see if the caps will reform. This would also show up any shorts across the HT supply.
7th Jul 2022, 8:38 am | #42 |
better picture of Burned out Resistor
7th Jul 2022, 8:45 am | #43 |
You need to start doing some testing.
7th Jul 2022, 11:16 am | #44 |
Graham what value should the Diode be ?
7th Jul 2022, 11:21 am | #45 |
7th Jul 2022, 11:34 am | #46 |
I've never had any trouble using 1N4007's, but some members prefer UF4007's
It would be a good idea to test the windings of the mains and output transformers before going much further. If they're faulty they'll be expensive to replace.
7th Jul 2022, 8:46 pm | #47 |
8th Jul 2022, 9:18 pm | #48 |
Hi Guys
I've removed the old burned out Resistor and the two rectifiers, do I need to remove the two metel brackets also, I have ordered a diode and a 150 ohms 10w Resistor, am I right in thinking one end of the diode goes to the red wire and the cathode - to the resistor and the other end of the resistor to the green . in picture, also I have purchased a Frolyt Cap 50uf 12/15v 70c to replace Red /Yellow Plessey 50uf 12v 70c, an I right to think the Black is negative |
8th Jul 2022, 9:53 pm | #49 |
Could this problem accorded if the Turn Table had seized up, as this item is from a Car Boot sale.
9th Jul 2022, 8:54 am | #50 |
I doubt it, the turntable motor load is on the input side (Anode) of the diode.
David |
9th Jul 2022, 8:59 am | #51 | |
I think you are correct about the connections but double check it all to make sure the connections match Lawrence's schematic. In this case the black end of the capacitor is the positive end (+ve), the plus (+) +ve sign is at that end. David |
10th Jul 2022, 8:42 am | #52 |
thanks David
14th Jul 2022, 9:30 pm | #53 |
Hi Guys
I've replaced the burned out resistor with 150 Ohms 10 Watt vintage wire wound ceramic resistor and a 1N4007 Diode as in picture and one of the yellow and red Caps with a Frolyt 50uF 12/15v 70C is so far okay also would that new resistor smoke a bit as its new? I need to do some more testing before I fire it up Regard Ken |
14th Jul 2022, 9:39 pm | #54 |
Is that tag on the transformer mounting screw insulated or connected to the transformer frame?
15th Jul 2022, 8:49 am | #55 |
Its insulated, however back to square one fired up and the new resistor over heats and burned off the solder to the diode, seems live too much power is going to the resistor, its hard to follow the schematics as I am not sure what relates to what as the board is so compacted.
15th Jul 2022, 9:14 am | #56 |
As I've said before, resistors don't cook unless they're passing excess current and they won't do that unless there's a problem with another component.
You have a problem down stream of the resistor. Check the resistance across the HT rail. I suspect you're going to find it's close to zero ohms, in other words a short-circuit.
15th Jul 2022, 9:59 am | #57 |
So far as I can make out the replacement rectifier shown in the 2nd photo in Post#53 looks to be connected the wrong way round...
Lawrence. |
15th Jul 2022, 10:09 am | #58 |
so the diode should go on the green wire and the resistor to the red?
15th Jul 2022, 10:21 am | #59 | |
If it's been powered up with a reversed connection on the rectifier I would replace the rectifier again and also replace the HT reservoir and filter capacitor at least and make sure the surge limiter is still ok. Lawrence. Last edited by ms660; 15th Jul 2022 at 10:44 am. Reason: extra info |
15th Jul 2022, 10:50 am | #60 |
is this right Lawrence
