Old 7th Jul 2020, 10:08 pm   #1
Matthew kane
Default Avo 2 panel valve tester set zero pot replacement
So now I have time to work on 3 of these testers one of them had a broken wound wire at the end of its wafer. I cannot repair it but I'm wondering if there is a replacement pot I can install in place.
It is the outer 1.8k winding.
Matthew kane is offline
Old 8th Jul 2020, 7:45 am   #2
Electronpusher0
Default Re: Avo 2 panel valve tester set zero pot replacement
I have just re-purposed the control part of a 2 panel AVO as a curve tracer and have the part you need spare but I have no idea what the postage to Australia would be.
PM me if you want me to look into it.
Peter
Electronpusher0 is offline
Old 8th Jul 2020, 10:51 am   #3
Matthew kane
Peter
Thanks for the reply Peter. Have to admit I'm more intrigued by your curve tracer implementation than the zero control although I would be interested in it as well but surely somebody has replaced it with a pot before.
Old 8th Jul 2020, 1:30 pm   #4
Electronpusher0
Peter
I am just testing it and preparing a write up for the forum but here's a taster.....
Peter
ID:	210551   Click image for larger version
Old 8th Jul 2020, 1:32 pm   #5
Electronpusher0
The problem is that the original is not linear as you can see from the shape of the winding.
peter
