15th Jan 2021, 2:25 pm | #1 |
Pre war Marconi radio
I've always wanted a pre-war set with the big valves and have just bought a 1937 Marconi radio.
The radio had to be posted and it survived the journey unscathed, the seller removed all the valves and packed them separately, so l put them all back in and l have to say the radio works very well. He said l would need a good aerial plus an earth, but l just connected it to the TV aerial in my workshop as l had nothing else to hand, and it works fine. It's obviously had some restoration in the past, as there are various components that have been replaced underneath. A couple of things, the valve pins are an unusual layout I've not seen before, and the speaker seems to be connected directly to the mains! l assume this is some kind of pre war technology. The cabinet is very good, l assume that's had restoration at some time as it can't be that good after 83 years. No idea why the photos came out sideways, they were straight when l uploaded them! Last edited by Cobaltblue; 15th Jan 2021 at 2:39 pm. Reason: don't use euphemisms |
15th Jan 2021, 2:44 pm | #2 |
Re: Pre war Marconi radio
Well done in getting you first pre war set
The speaker is what's known as "mains energised". Its not actually connected to the mains but it will be in the HT circuit. The valves are probably B4, B5 and B7 pretty common in UK sets up to the end of the 1930's Your pictures are probably sideways due to using an Apple device sorry to say they are famous for not knowing which way is up! I will see about rotating them. Cheers Mike T
15th Jan 2021, 3:08 pm | #3 |
Also, if it has a gram or pickup at the back you can use it to play pretty much whatever you like. It's basically a mono audio-in socket.
15th Jan 2021, 3:12 pm | #4 | |
I would check to see what has been replaced, a set of this vintage should have any remaining original caps replaced, as leaky old caps can cause damage to transformers & valves. A photo of the underneath of the chassis would show us what has been done & needs doing. Mark |
15th Jan 2021, 3:28 pm | #5 |
From the photo's it looks like a Marconiphone 557, if it is then the loudspeaker field coil will be in the HT-ve circuit, the voltage developed across that is used for the valves bias supply.
https://www.service-data.com/section.php/4467/1/557 Lawrence. |
15th Jan 2021, 3:46 pm | #6 |
Its nice to know that sets like this are being sort and restored, and the fact that lightning is venturing into this lovely hobby.
Ken |
15th Jan 2021, 4:04 pm | #7 |
Looks lovely, I'm guessing it's been restored somewhat. And nice to know it survived the journey! I wish there were some way to let the designers know it's still working
Kevin |
15th Jan 2021, 4:48 pm | #8 |
The 1930's is my favorite period for lots of things from radios to furniture to cars to areoplanes.... such amazing designs, just awesome! This is one of my Marconi radios...
15th Jan 2021, 8:30 pm | #9 |
Very nice set Lightning! There was a recent thread re replacing a mains energised LS. If there is room the M Eng coil may sometimes be left in for convenience, even if a "modern" permanent magnet LS is fitted as a replacement!
The valves are only unusual to you as Mike suggested .... until you venture into pre-war heaven! Do you know about side contact valves of the period at all?. See the recent interesting thread "Why was the CT8 [side contact valve] developed? 16/12/20. Some of these had 4v heaters at high current which can make restoration a bit tricky sometimes! Dave W Last edited by dave walsh; 15th Jan 2021 at 8:36 pm. |
15th Jan 2021, 9:06 pm | #10 |
I too love this style of set! Here's one I restored some years ago waiting to go back to its owner...
https://www.radiocraft.co.uk |
15th Jan 2021, 11:03 pm | #11 |
It's a very nice looking set, with some subtle Art Deco styling.
15th Jan 2021, 11:16 pm | #12 |
Really nice set, I always think the "golden age of radio" is the 1930's, and there are so many fine pre-war sets still out there and not costing the earth.
Clive |
16th Jan 2021, 10:54 am | #13 |
Late 1930's sets from HMV, Marconi, Murphy, RGD, and Dynatron are my favourites.
Time flies like an arrow, fruit flies like a banana |
16th Jan 2021, 6:13 pm | #14 |
Thank you for all the replies, we've put the radio in the lounge where it can be used from time to time, although it means my Bush TV24 is relegated to the spare room.
The TV 24 is in working order, l renovated it about 10 years ago with help fro a friend who used to repair them back in the day. l would be happy to purchase another pre war radio if anybody is selling one, or knows of a good one! Here's the TV24..... it's in remarkably good condition. |
18th Jan 2021, 10:40 pm | #15 |
I have the same model as yours and one of the ones shown in Panrock's post. They are basically the same except that Panrock's seems to have been the deluxe model with a slightly bigger case with more veneering and a tuning indicator. There were a couple of radiograms with the same chassis. As others have said they are great sets with an rf amplifier stage and were very well built. They have the infamous EMI pitch filled capacitor block but that is messy rather than a great problem to re-stuff.
I agree with rontech's choice of manufacturers of 1930s sets. I am also quite a fan of McMichael products.
Paul |
