Old 15th Jan 2021, 7:42 am   #1
KW2000A
Default Inrush Protection PTC?
Greetings
Confounded modern component....from a small SMPS. It's additional to a fusible link . Am I correct that its for Inrush Current Protection? Otherwise please enlighten me...having another senior moment.
Best Wishes....Phil
KW2000A is offline
Old 15th Jan 2021, 9:10 pm   #2
buggies
buggies's Avatar
Default Re: Inrush Protection PTC?
Looks like it
Thermal links / Resistor assemblies is a product that combined with thermal links of fusible alloy type and 1W wire wound resistor type.
F1K is RoHS compliance product, non-Pb and non-Cd contains.
F1K got excellent interception characteristic when abnormality overload happened.
Especially, F1K adopted excellent characteristic resistive element against the In-rush current, and it is the best for preventing In-rush current.
According to :-https://www.uchihashi.co.jp/en/fuse/f1k/
George
buggies is offline
Old 16th Jan 2021, 4:08 am   #3
KW2000A
Great.Many thanks George - useful reference too.
Mods: thread can be closed with thanks.
Best Wishes,Phil
KW2000A is offline
Old 16th Jan 2021, 6:37 am   #4
trobbins
trobbins's Avatar
I don't see any confirmation on that website that the resistor element is a PTC. There is the reference to in-rush prevention, but also a reference to wire-wound resistor. The spec relates to the resistance tolerance (presumably of the part number related resistance value), and the the functioning temperature (presumably of the thermal fuse element). The in-rush descriptor could just be related to the ability of the fixed resistance to survive an in-rush.
A supporting tech sheet I just located:
http://www.bayside.com.hk/catalog/im...ducts/F1K2.pdf
trobbins is offline
Old 16th Jan 2021, 10:03 am   #5
Julesomega
Julesomega's Avatar
Does the measured resistance change with temperature? Soldering iron or freezer spray?
- Julian
It's good here
Julesomega is offline
