12th Jan 2021, 3:28 pm | #21 | ||
Re: Bush DAC90A - Very Low Volume
Heater voltage (Pins 1-8): 12.82V AC Pin 2: 58.5V Pin 5: 0.2V Pin 7: 0.6V Quote:
R7 (100kΩ) is the V3 Grid Stabiliser at this location and is connected to Pin 3 - this has been replaced and is reading 100.6kΩ The IF Filtering Cap C12 (100pF) must be one of the most inaccessible components in this set! Impossible to get a reading for this and C16 (50pF) without taking these mica caps out of circuit - if I'm doing that I may as well replace them! Only value I could get with my ESR meter for C12 was 461kΩ
BVWS Member |
12th Jan 2021, 3:41 pm | #22 |
Check that R9 150k, the anode resistor on pin 2, hasn't drifted high in value.
12th Jan 2021, 3:46 pm | #23 |
Has C17 been replaced? And by what value? Original was 0.003uF, I think.
It's a tone corrector, mounted chassis to tag board, next to the volume control (I believe the earth connection for the cap uses the O/P TX mounting bolt(?)). It's not uncommon for these to be hiding under the tag board itself ... sneaky. If this is resistive, it could keep the set quiet. Mark
Slowly turning the 'to-do', into 'ta-dah' |
12th Jan 2021, 3:59 pm | #24 |
The manufactures voltages/current around V3 don't make sense anyway so far as I can make out.
Lawrence. Last edited by ms660; 12th Jan 2021 at 4:08 pm. Reason: addition |
12th Jan 2021, 6:09 pm | #25 | |||
*** As I noted in my Post #1 above " ... I replaced all the old paper caps one at a time along with any resistors which were 20% over tolerance" - good though to re-check everything, just in case! In my Post #21 above I also noted that I was finding it almost impossible to get a reading for C12 (100pF) and C16 (50pF) without taking these mica caps out of circuit. What I'd like to know before proceeding is whether or not faults with either (or both) of these mica caps could account for the very low volume I have with this set?
BVWS Member |
12th Jan 2021, 6:47 pm | #26 |
C12 is wired across the volume control so its value cannot be checked in circuit. The fact that you're measuring 461kohms (ie the resistance of the volume control) across it shows that it's not short-circuit, but it could be breaking down in service.
With these impossible faults all you can do is:- Check the wiring accounting for every wire and component on every tag. Check that new components have the right value, it's easy to misplace a decimal point where capacitors are concerned. Check all components to make sure they're not faulty. Clutching at straws does the output transformer's primary measure correctly in circuit? If there's a short across it it will make little difference to the voltage readings, but the amplifier won't work.
12th Jan 2021, 6:52 pm | #27 | |
[I've had this with modulation transformers in some 'sixties mobile-radio gear: winding resistance values were within 5% of the specified values but the thing never managed more than about 30% of the intended output....] |
12th Jan 2021, 7:07 pm | #28 | ||
The output transformer's Primary measures 702Ω in circuit and 16.2V across the two tags? How would I go about checking for shorted-turns?
BVWS Member Last edited by DonaldStott; 12th Jan 2021 at 7:25 pm. |
12th Jan 2021, 7:21 pm | #29 |
Given that the O/P transformer was rewound by Ed Dinning I very much doubt it has shorted turns.
Is C20 the correct value? 0.01uF or 10nF, 500V or greater.
12th Jan 2021, 7:30 pm | #30 |
Testing for shorted-turns on an output-transformer is not going to be easy with typicl testgear; it's the sort of part where a service-manual is likely to say "Test by substitution!", which is OK if you happen to have a spare. In practice almost any small-valve-radio output transformer will be a 'near enough' for a test-by-substitution.
EDIT: I hadn't noticed that the transformer has already been rewound by a trustworthy source! |
12th Jan 2021, 7:51 pm | #31 |
External signal in at V4 g1 (via a capacitor) then take it from there.
Lawrence. |
12th Jan 2021, 8:16 pm | #32 |
To state the obvious, given that you have tuneable signals with your signal tracer at the slider of the volume control, that exonerates the RF and IF stages. And given that you can hear signals from the speaker, but at much reduced volume, that indicates that the detector stage is working. That points to the IF amp (V3 triode section) and the AF amp (V4).
That's the area marked in red on the part circuit below. As to Voltages, of all the DAC90As that have passed through my hands, I've never had one yet in which, in all respects, the voltages compare with the spec., but that said the datasheet was based on voltage being take with the radio on the MW with so signal tuned in, using an AVO 7 (1,000 OPV) on the 1,000V range for HT measurements, and for low voltages (cathodes etc), on the 10V range. Using a digital multi-meter with maybe 20 M Ohm input impedance, the voltages will differ to an extent, but not perhaps by much. Some variations will arise due to different mains voltages. For example, locally, the mains voltage is 237V, so If I set the dropper at 250V to be kinder to the valves, the voltages will be lower than if I set it on the 230V tapping. For what it's worth I've attached the table of voltages on my working DAC90A (and what was until a few days ago), the non-working one. The fault which caused the malfunction in that set was an IFT capacitor and that had no bearing on the voltages. Both sets are now working really well, except that the mains switch on the 'working' one doesn't now switch off so I'm going to have to fit a new 470k Pot. If you're satisfied by substitution that V3 & V4 are sound, I can only suggest you focus on the area of the circuit I've marked in red. Hope that might help a bit. Good luck with it.
12th Jan 2021, 8:58 pm | #33 |
Hi Donald,
More to offer moral support , more than anything else! So you have essentially rebuilt the whole receiver, and still no joy. That must be very frustrating and I hope you can solve this... Wild card: did you ever check C20? I've known failure of the capacitor serving this role. Watching with interest!
Al Last edited by Al (astral highway); 12th Jan 2021 at 9:07 pm. Reason: To avoid confusion. |
12th Jan 2021, 9:08 pm | #34 |
Is not V3 an AF amplifier?
12th Jan 2021, 9:56 pm | #35 | |
Thanks to everyone for giving up their time to contribute to my DAC90A problems - as usual I've learned lots of new stuff along the way which will be catalogued and stored until the next time. Unfortunately we don't yet have a successful outcome and I have a few more things to try but I am more convinced than ever that the problems, whatever they may be, are probably of my own making!
I fully agree with David's comments in Post #32 above about DAC90A voltages i.e. "I've never had one yet in which, in all respects, the voltages compare with the spec." Nevertheless he has helpfully narrowed down any further investigations to the area outlined in RED in his attached circuit diagram - thanks David. It will be a question of working my way through every component, every wire and every connection shown - I thought I'd already done that but there must be something I've missed! Quote:
I think I'll put this DAC90A back on the shelf for a few weeks until I've got the stamina to tackle all those checks!
BVWS Member |
12th Jan 2021, 10:49 pm | #36 | |
thanks for reading the post Graham - my mistake - well spotted.
12th Jan 2021, 11:08 pm | #37 |
Confused by calling the output stage the AF Amp (which it is of course) and looking to call the previous stage something else maybe?
Could call them AF Voltage Amp and AF Power Amp I suppose....
12th Jan 2021, 11:37 pm | #38 |
I read through this little lot thoroughly, I think. I noted the speaker had been repaired, has it actually been tested?
13th Jan 2021, 12:08 am | #39 | |
Speaker has been repaired and tested with a known working DAC90A but thanks for the suggestion.
BVWS Member |
13th Jan 2021, 12:19 am | #40 | |
Donald, now that you’ve checked the speaker, what about C20? The reason I mention it is that in some fault conditions, EHT can develop on the primary side, making this leaky. This was linked to the first ever problem I encountered in a valve radio. That would be one candidate for your symptoms. May as well systematically work backwards from one side of the speaker into that red zone.
Al |
