10th Jan 2021, 9:17 pm | #21 |
Re: New lease of life for empty clock case.
If the sockets on the left are for a pickup, where was the high impedance speaker supposed to connect?
The RH side connector and labeling appear to be the mains supply with my minimal knowledge of German. To clarify, my mains connection comment was regarding the lack of anchoring for the cable which was why I supposed it was a temporary setup. Ian |
10th Jan 2021, 10:37 pm | #22 |
If you look closely at the 3rd picture in the first post, you can see the speaker connections with a yellow and green plug in them, just in front of the valve on the right, next to the mains transformer.
Regards, lloyd |
10th Jan 2021, 10:44 pm | #23 |
I can see where the speaker is connected now, but my query was where did Telefunken expect it to be connected?
The diagram shows ground, antenna, mains etc but I dont see the speaker. (Use of clock case is a brilliant idea though) Ian Ian |
10th Jan 2021, 11:04 pm | #24 |
Clever work Mick.
10th Jan 2021, 11:09 pm | #25 | |
Regards, Lloyd |
10th Jan 2021, 11:46 pm | #26 |
11th Jan 2021, 10:21 am | #27 |
I was thinking that the set have been adapted in the nazi era for clandestine listening to broadcasts from the UK. Given the spies everwhere situation, if there was no loudspeaker and headphones only were used, the chance of discovery would be reduced considerably.
Time flies like an arrow, fruit flies like a banana |
11th Jan 2021, 10:28 am | #28 |
Are we agreed that this set originally HAD an internal loudspeaker?
11th Jan 2021, 10:31 am | #29 | |
For example here's a Lumophon which did the same thing: Lumophon w23 and here's the same Lumophon with an inbuilt speaker: Lumophon GD23
Stuart The golden age is always yesterday - Asa Briggs Last edited by bluepilot; 11th Jan 2021 at 10:43 am. Reason: Added bit about Lumophon |
11th Jan 2021, 12:05 pm | #30 |
I have just found this on the radiomuseum site.
Country: Germany Manufacturer / Brand: Telefunken Deutschland (TFK), (Gesellschaft für drahtlose Telegraphie Telefunken mbH Year: 1930–1932 Category: Broadcast Receiver - or past WW2 Tuner Valves / Tubes 4: REN1004 REN1004 RE134 or RES164 RGN354 Main principle TRF with regeneration; 2 AF stage(s) Tuned circuits 1 AM circuit(s) Wave bands Broadcast (MW) and Long Wave. Details Power type and voltage Alternating Current supply (AC) / 117; 220 Volt Loudspeaker - This model requires external speaker(s). Power out from Radiomuseum.org Model: 33W - Telefunken Deutschland TFK, Material Bakelite case Shape Tablemodel, with any shape - general. Dimensions (WHD) 380 x 250 x 170 mm / 15 x 9.8 x 6.7 inch Note the reference to needing external speakers.
11th Jan 2021, 12:48 pm | #31 | ||
But why were the speaker connectors not indicated with all the other connections on the diagram I wonder. Ian |
11th Jan 2021, 1:02 pm | #32 |
Was it common in Germany to use a non-metallic panel for mounting the valve-holders etc for the lower end models? I suppose that it's a resin-bonded paper laminate like Paxolin in the UK.
Not much in the way of screening though. |
11th Jan 2021, 1:04 pm | #33 |
Great work. Just done a 'shade & light' adjustment to the second photo using Photoshop.
11th Jan 2021, 2:37 pm | #34 |
Thanks Steve, the only Photoshop I know about is the one in town , sorry Mick.
11th Jan 2021, 2:42 pm | #35 |
It's funny you should mention screening Neil, there is a slight grid hum ,when touching the area around the first valve it increased, as if the paxolin has gone slightly conductive ,I may try a screen , Mick.
11th Jan 2021, 2:46 pm | #36 |
11th Jan 2021, 3:41 pm | #37 |
I like that a LOT!
Excellent re-purposing job, looks the part & just seems to "fit". Well done!
The difference between stupidity and genius is that genius has its limits. (Einstein) |
11th Jan 2021, 4:14 pm | #38 |
The clock was a Smiths "Troon" if time-only, a "York" if striking, or the Enfield-badged version thereof. Circa 1950. Still very common and work well once serviced. There were only a few pendulum clocks which used Bakelite cases; it was much more common for little electric timepieces and alarm clocks. This surprises me as they can look lovely, and sit nicely in a room with a DAC90A. Maybe people still wanted a living room centrepiece which was made from wood.
There is at least one example of a radio built into a surplus Bakelite clock case in Radio! Radio! I think. Last edited by Nickthedentist; 11th Jan 2021 at 4:27 pm. |
12th Jan 2021, 9:58 am | #39 | |
Very good idea to repurpose the case as a loudspeaker, I have two of these clocks, I made one good one out of the two, as one had a broken door hinge & smashed glass, but the mechanism was good, the other was mint, but had a worn out mechanism.
The spares clock was going to have the frowned upon Quartz conversion, but would make a good test speaker for the workshop! Mark |
12th Jan 2021, 2:19 pm | #40 |
This should please Ian "elanman99 " I have fitted a two pin plug ,I found a nice round plug drilled a hole in it and fixed it to the original panel, also made a back , all finished now . very pleased with the result, Mick.
