5th Jan 2021, 10:21 pm | #1 |
Temperature & humidity monitoring
Hi, I was wondering if anyone can recommend a temperature monitoring system?
Basically, I would like to monitor (ideally with an app) the temperature & humidity of the following locations: 1.) The loft 2.) The garage 3.) The big shed 4.) The small shed Ideally, a wireless system, though the two sheds are going to be out of range, so wired may be the best option for a complete system, although running cables could be a pain. I have been browsing some of the products on Lascar electronics-lots to choose from ! But hoping for some recommendations. Many thanks, Retrotechie |
5th Jan 2021, 10:35 pm | #2 |
Re: Temperature & humidity monitoring
I have a couple of Casella Thermohygrographs - clockwork, one week on a drum chart, vintage....errr not at all electrical!
"The best dBs, come in 3s" - Woody Brown |
6th Jan 2021, 12:14 am | #3 |
Hi Retrotechie,
I investigated this a year ago. Some parts of our house suffer from damp. I bought 2 dehumidifiers but I wanted a way to measure what was actually going on. I had an existing weather station which included a humidity sensor on the outdoor unit and an indoor sensor which did temp/humidity. I also did a lot of research on the humidity sensors available as part of smart home systems - all that home automation stuff - "alexa, switch on the living room lights at 6pm". But all the components were very expensive, for what you were getting. So I ended up buying 3 extra sensors to work with my weather station: https://www.ecowitt.com/shop/goodsDetail/55 and I use these to monitor humidity and deploy my dehumidifiers. The range is pretty good - they use RF frequencies not wifi. And now they come with an app - no need to use them as part of a weather station setup. Edit: [after reading their website you do need this central unit: https://www.ecowitt.com/shop/goodsDetail/16 then you can add more sensors] -Steven Last edited by stevenkw2t; 6th Jan 2021 at 12:19 am. Reason: update info re use of sensors |
6th Jan 2021, 10:56 am | #4 |
Not quite what you have in mind, but I use a product called Sensor Blue ... https://www.amazon.co.uk/Brifit-Ther...a-925637116923
It is stand alone and communicates via bluetooth with your smartphone. The app, available for android or iphone, indicates temperature, humidity and dew point. Also, the unit records the temperature, so you can look at trends. OK, you have to be in range to take a reading, but how often are you going to look? The unit itself shows temperature and humidity on its own display. Had my units over a year and still going well on the original batteries. Colin |
6th Jan 2021, 6:51 pm | #5 |
I used to be a very keen weather observer way back, in the garden I had my max/min thermometer, and other typical sensors which I used to record in my note book. Today I’ve got a basic system with three remote sensors and a display inside the house, I don’t record any data today. One problem I experienced was location of remote sensors, no signal from bottom of garden, which happens to be the best location, so be aware of that, which I think you mentioned in your post.
John |
6th Jan 2021, 7:04 pm | #6 |
My external wireless thermometer doesn't give very accurate results in winter because it tries to run on a single cell which means it stops working when it gets cold - the time I really want the answer!
There was a suggestion of trying it on a Li battery but for some reason this is too much voltage and sends it into a latch-up state. |
6th Jan 2021, 7:25 pm | #7 |
My old remote sensors never failed to work down to approximately-5C. I live by the sea so it doesn’t often go well below 0*C.
John |
6th Jan 2021, 10:42 pm | #8 |
Hi.
I have a cheap Lidl weather station that does inside and outside temperature, it runs on AA batteries and has been fine even below -7c no humidity sensor unfortunately, it also has a radio controlled clock. It's wireless from the outside sensor.
6th Jan 2021, 11:44 pm | #9 | |
7th Jan 2021, 5:24 pm | #10 | |
The only other issue is having to remember to set up the clock as minus 1 hour, the signal comes from Frankfurt!
Rick, the annoying object roaming the forum. |
