Old 5th Dec 2020, 12:30 am   #1
1980s_john
Default How to remove strap handle?
I would like to remove a rusty strap handle to clean it, but I can't work out how to remove the end caps. These cover the bolts which hold the handle in.
Attached are some photos.
I think these new ones are similar:
https://www.ebay.co.uk/itm/Strap-han...e/333042185605
Thanks,
John
Name:	handle front.jpg
ID:	221893   Click image for larger version
1980s_john is offline
Old 5th Dec 2020, 8:33 am   #2
ajgriff
ajgriff's Avatar
Default Re: How to remove strap handle?
They usually clip into place. A little gentle levering with a small screwdriver should do the trick. You may find that the other side of the clip isn't rusty. I've turned them inside out before now as the metal is quite thin and is easily manipulated. The rusting looks quite light anyway so they may clean up with some metal polish.
Alan
ajgriff is offline
Old 5th Dec 2020, 9:02 am   #3
stevehertz
stevehertz's Avatar
Alan
You've turned a metal, press formed decorative end clip inside out?!
stevehertz is offline
Old 5th Dec 2020, 9:09 am   #4
Nuvistor
Nuvistor's Avatar
I thought they slid down to remove those clips.
Frank
Nuvistor is offline
Old 5th Dec 2020, 9:21 am   #5
ajgriff
ajgriff's Avatar
Slightly different fixing arrangement but same principle.
Alan
Name:	Farnell L30 Handle.jpg
ajgriff is offline
Old 5th Dec 2020, 9:52 am   #6
60 oldjohn
Originally Posted by 1980s_john View Post
Thanks,
John
No I don't believe these are the same. Is there not a nut inside the case? Think of this as a bolt with a fancy polished (or in your case rusty head)
I have just done one on an Ever Ready Sky Emperor, I was lucky many sets used this make of fastener around the 1950s I had an Identical handle on a scrap set that was in better condition. It cleaned up really nice.
Edit, just seen your second picture, If the nuts are part of the case (Have you tried moving ONE of them?) then I think the metal Cover should knock to the left using hammer with a scrap off wood to protect the metal.
John.
My favourite text message "I'll be there in five minutes, if not read again"
60 oldjohn is offline
Old 5th Dec 2020, 10:21 am   #7
stevehertz
stevehertz's Avatar
Alan
Well ok, but that's a totally different kettle of fish to the one that the OP has, hence, with respect somewhat misleading advice. If he tried to turn that one inside out it would be scrap.
Old 5th Dec 2020, 10:33 am   #8
1980s_john
The nuts inside the case are welded in place. I will try the hammer and piece of wood, I tried levering with screwdrivers without success.
Thanks,
John
Old 5th Dec 2020, 10:36 am   #9
ajgriff
ajgriff's Avatar
My advice was offered in good faith and I don't think that John's clips are a 'totally different kettle of fish' so we'll have to agree to differ. Who'd have thought that a simple clip would cause such controversy?!
Incidentally the clip in question may well have a lip on its leading edge preventing it from being slid or knocked backwards. On the other hand it might not.
Alan
ajgriff is offline
Old 5th Dec 2020, 12:00 pm   #10
ajgriff
ajgriff's Avatar
Here's a photo of a similar cover once removed. On this one there's a lip at the front and a dimple at the back to retain the cover over the handle fixing. I removed it by levering with a screwdriver at the back (dimple end). I hope nobody finds this misleading.
Alan
ajgriff is offline
Old 5th Dec 2020, 12:01 pm   #11
60 oldjohn
Alan
That is possible. In that case best use the two sides to tap on, one side at a time unless you have four hands, two hammers and two pieces of wood!
John.
Crossed with Alan, If Johns handle is like Alans my idea would not work. I had only seen them with a small downwards lip.
Old 5th Dec 2020, 12:32 pm   #12
Refugee
Refugee's Avatar
Last time I removed one I just put a small leaver under the end furthest from the strap and it just clicked off. When done it just pressed back on by hand.
Refugee is offline
Old 7th Dec 2020, 9:53 pm   #13
1980s_john
Thanks, this was exactly right. I only proved this after a bit off hammering, no equipment was harmed! Not sure what type of handles these are, bracket says 'Made in Germany', equipment was from around 1979.
Regards,
John
ID:	222061   Click image for larger version
ID:	222062   Click image for larger version
Old 8th Dec 2020, 12:18 am   #14
Refugee
Refugee's Avatar
That strap cap sure has kept the fixing hardware underneath clean and shiny.
Refugee is offline
Old 8th Dec 2020, 10:48 am   #15
DMcMahon
DMcMahon's Avatar
Very interesting and useful to see this Thread as I have several rusty handle straps on some of my tape recorders.
DMcMahon is offline
