Old 26th Dec 2020, 6:53 pm   #1
cathoderay57
Default Eddystone 750 BFO Trouble
My Eddystone 750, that had been an excellent performer on SSB, providing that I backed off almost completely the RF and IF gain controls (on account of the deliberately low level of BFO injection), started giving BFO trouble. Resolving SSB became nigh on impossible unless I off-tuned a lot more than normal, using the main tuning dial, in which case the audio level dropped to almost inaudible. There was also a high pitched hiss which varied in pitch as I adjusted the BFO tuning knob. Sometimes it seemed OK but as soon as I touched the BFO knob the problem kicked off. Reception was fine on AM. I suspected BFO instability so I checked the anode supply voltage to the 6BA6 (V9) which was about 148v. I could not measure test point Y, the actual anode voltage, which is only accessible from within the BFO coil can and should be 75v following R44, a 47k anode load resistor, according to Eddystone service data. Maybe a bit high then - but at least I had got anode volts. Out came the BFO coil can and I opened it up. The anode and grid 1 resistors (both 47k) checked out OK. I decided the silvered mica caps were almost certainly innocent so all that was left was 3 x 10nF decouplers, one on grid 2 and one each between the heater connections and chassis. See attached. The heater decouplers had turned into low value resistors and the grid 2 decoupler seemed to have lost capacity. I decided not to muck about testing the caps any further and just replaced all 3 with new. Reassembly was straightforward and normal service resumed. Jerry
cathoderay57 is offline
Old 26th Dec 2020, 7:00 pm   #2
Default Re: Eddystone 750 BFO Trouble
I had 'overload issues' with the AGC on "Steady Eddy", my 840A bedside radio - which after much annoyance turned out to be one of those 'rat-turd' capacitors buried deep within the coil-box as part of the RF amp control-grid feed, which had decided to forget about doing the capacitance-thing and had re-identified as a 70KOhm resistor.
See them, replace them. They're not to be trusted.
Old 26th Dec 2020, 7:05 pm   #3
ronbryan
Jerry
When you need to measure a valve electrode voltage, or inject a signal when the valve base is inacessible, but the valve is exposed, such as in a FM tuner for example, I have used a short piece of 1/0.6mm silver-plated ptfe wire stripped at the end and looped tightly around the valve pin to make a connection.
Ron
ronbryan is offline
Old 26th Dec 2020, 10:35 pm   #4
cathoderay57
Thanks for the replies - useful tips. Jerry
Old 7th Jan 2021, 1:12 pm   #5
John Caswell
Hi all,
I think these components are Hunts capacitors.
If so, I have had horrendous problems with them in Quad QC22 preamplifiers in the tone control circuits, so much so, that I now replace them on spec. There is nothing consistent about them as to the "fault" high, low, open, short, I have had them all.
If there are any others in this Eddystone 750 I would most certainly contemplate replacing them.
John Caswell is offline
