18th May 2019, 2:40 pm | #61 |
Re: Any other plug collectors out there?
Here's some grotty back of the garage photographs of the grey one, with sleeved pins and branded Legrand.
18th May 2019, 2:49 pm | #62 |
Thanks for that photo. The Legrand website only lists current products so there are no mentions of the colour range that they came in.
Al
I won't tell you how I discovered that. |
18th May 2019, 3:03 pm | #63 |
I don't collect plugs per-se but do have some modern 2A round pin sockets in the lounge. These are connected to the three way light switch, middle is the main (ceiling) light and the other two alternate between the six 2A ones round the room. And my Magneta (PO36) clock system is powered from a proper vintage 5A job.
And before you ask the 2A sockets are supplied from a 2A MCB, the 5A one from a 5A MCB. |
18th May 2019, 3:24 pm | #64 |
I have lots of those Legrand plugs, all in everyday use around the house. Both sleeved and unsleeved.
They're my favourite plug ever. Back in the 80s, my sister in law worked at Blackburn's premier independent ironmongers, and had a very generous staff discount, so I was able to buy rather a lot of these lovely plugs for very little money. Ah! I miss those days.... And, my brother also had a red one on his welder. The outer cover of the cable was far too thick for the entry hole, so he he just stripped more of it off, and had the three inner cores clamped by the cord grip instead. It used to get quite hot sometimes, but never melted at all. Unlike some previous good quality plugs did. He had an MK safetyplug on at one point, with a bit of metal bar in place of a fuse, which gradually burnt its way out through the top of the plug. The things we used to do, eh!
Best Regards, Peter. Last edited by Lancs Lad; 18th May 2019 at 3:40 pm. |
18th May 2019, 3:40 pm | #65 | |
The earth pin is T shaped with the shank width a reduced thickness. This prevents a normal 13A plug which could have a high current rated appliance being plugged into the UPS supply and tripping it. Also the T shape earth pin cannot fit into a normal 13A socket. Christopher Capener
Interests in the collection and restoration of Tefifon players and 405 line television |
18th May 2019, 9:03 pm | #66 |
De-La-Mere was another company that made coloured plugs.
I think my Mum had a Legrand plug on her hairdryer, certainly it was a square one.
18th May 2019, 10:23 pm | #67 |
I love those modern transparent plugs often supplied with table and standard lamps where you can see the value of the fuse and if the wiring has been done correctly, although I don't remember owning one myself.
-- Graham. G3ZVT |
18th May 2019, 10:26 pm | #68 |
I've got a 15-Amp round-pin version of one of those somewhere. I think it was originally aimed at the South African market.
18th May 2019, 10:27 pm | #69 |
Mention of coloured plugs reminded me of the red 'BHS' branded plug from British Home Stores. I'm sure I've seen a blue one out there somewhere. It was unusual in that the three cores were routed differently form the 'traditional' layout, as shown in the photos. I also have some coloured W&G plugs as well.
18th May 2019, 10:33 pm | #70 |
Another brand of coloured plugs was "Rock" - I've got a duck-egg-blue 13A Rock plug on my Philips B2X67U
18th May 2019, 10:52 pm | #71 | |
In my case the Deathdapter was supplied with a cheap hand-head transceiver ordered from China The other thing that the general public would not necessarily perceive as a problem, are those slim moulded-on plugs on imported products that do not have a fuse. I spied one on an LED window sign in a chemist shop where I was working and pointed out to the owner that the only protection was the 32amp breaker in his CU. To compound matters further, the mains lead connected to these plugs is very often a few strands of copper covered steel.
-- Graham. G3ZVT |
18th May 2019, 11:25 pm | #72 | |
18th May 2019, 11:28 pm | #73 |
Hi Graham.
I have one of those transparent plugs. It came on a table lamp that I bought from Sainsbury's. The flex is transparent too, and so is the inline switch. Also, the flex doesn't have coloured cores, either, which I suppose doesn't matter too much as it's just a simple lamp. It's a strange feeling, actually being able to see all those metal parts and the fuse, knowing that they are all live
Best Regards, Peter. Last edited by Lancs Lad; 18th May 2019 at 11:36 pm. |
19th May 2019, 12:32 am | #74 |
There are even one or two slim non-repairable plugs out there.
You would not think there is a fuse in it until you turn it over and see that it is there with a maximum rating of 5 amps emblazoned on it. The other end is a C-13. It has been in use in a dusty location for some years and the camera flash sure shows it up. |
19th May 2019, 1:10 am | #75 |
Oh yes! I had one of those, too, Refugee.
It was bright orange, on a Flymo strimmer.
Best Regards, Peter. |
19th May 2019, 2:33 am | #76 |
I just used it where a gas igniter lead was too short and it was quickest to fit a screw terminal C-14 in place of the rewireable plug that was already fitted.
It was a lot quicker than stripping a gas hob down to fit a longer lead. |
19th May 2019, 9:59 am | #77 |
I've got one of those slim Legrand/BICC plugs which is marked 'MANWEB' - Merseyside And North Wales Electricity Board. Also, an old Ediswan plug marked 'SWEB' - South West Electricity Board. Cheers, Pete.
19th May 2019, 10:21 am | #78 |
Quick question about something that's got me puzzled!
I sometimes see this little 'S' icon beneath various usernames. Can anyone tell me what it denotes, please?
19th May 2019, 11:59 am | #79 | |
19th May 2019, 12:02 pm | #80 |
I've got a number of De La Mer plugs on and off different things, in Blue, Orange and Red. I don't know anything about "de la mer", it translates to "of the sea" in French, which is a strange choice of branding for an electrical accesory.
