23rd Sep 2020, 3:25 am | #41 |
Re: Bat Detector with Knowles Ultrasonic microphone problems
Some progress with the split supply. The signal generator is attached to VGND and IN, at 40kHz. I have only my remaining LM358 in place, acting as the unity gain stages. First picture is the output of the first LM358 with the split supply, on pins 1 (Inverting stage, upper trace) and 7 (non-inverting, lower trace). The second shows the split supply disconnected.
The only downside is that they're not inverted compared to each other! I can now see Peter's point that the supply is referenced to 1/2 Vcc on the microphone board. Why that is not carried through, as the trace suggests, I don't know. |
3rd Oct 2020, 2:15 pm | #42 |
I've got some output in the headphones, so I'm pushing on to make it up on veroboard. In the end, I've got some of the original author's ICs as I was rounding up a Farnell order. I'm going to make two detectors - one 5V and one 3.7V.
Has anyone any bright ideas for attaching the microphone board to the enclosure? I'm using one of those Hammond die-cast ones, intending to drill a tiny hole to coincide with the mic. I suppose I ought to glue the little mic board to the inside of the enclosure, but then I considered that the holes for the wires come through and would short out. Perhaps a mica sheet in between? Fish paper? Would either of these attenuate the ultrasonic signals? |
