23rd Nov 2022, 5:45 pm | #1 |
[NEED ADVICE] Marantz CP430
Ok, so I was going through the unit to see if I could troubleshoot a problem with the pitch control not working. It took me a while to spot this swollen capacitor next to the power supply input. Do you think it might be related to the issue and even if not should I worry about it?
23rd Nov 2022, 6:29 pm | #2 |
Re: [NEED ADVISE] Marantz CP430
With its end bulging like that it definitely needs changing. Whether it will fix your problem I cannot say.
23rd Nov 2022, 6:43 pm | #3 |
Absolutely, that is a very sick capacitor. Look carefully at any others from the same manufacturer with similar values too.
23rd Nov 2022, 6:47 pm | #4 |
Thank you kindly for the replies!
What do you mean with the second sentense? Does that refer to the replacement cap I will look for or for any other bad ones on the unit? |
23rd Nov 2022, 6:52 pm | #5 |
Re: [NEED ADVICE] Marantz CP430
No, look for any similar capacitor from the same manufacturer ALREADY PRESENT that might have failed. Look for any sign of bulging or leakage. If anything is suspicious, change.
23rd Nov 2022, 8:53 pm | #6 |
The pitch control RS06 varies the control potential on pin 2 and Pin 3 of QM01 (AN6612) on PCB ref. PM01 and the defective electrolytic could certainly affect the operation of this device, but I can't pick it out on the rather grotty scan of the service manual!
The control RS06 is a special centre–tapped type connected in such a way that it varies the nominal speed of the motor above and below the nominal centre–point setting, which occurs when the wiper of RS06 is adjacent to the centre–tapping on the track of RS06. A contact on the record/playback switch is provided to automatically take the pitch control out of circuit on the "record" position since (under normal circumstances!) you always want the recording speed to be at the correct nominal figure of 1⅞ i.p.s! Service Manual :– https://www.manualslib.com/manual/11...ntz-Cp430.html AN6612 Datasheet :– https://www.alldatasheet.com/datashe...IC/AN6612.html Replacement Device :– https://www.ebay.co.uk/itm/201618747...mis&media=COPY Don't forgot to test the pitch potentiometer RS06 itself with a multimeter, and the wiring to it between boards RS01 and PM01 (see circuit diagram in manual)! Another possibility is a fault in transistor QM02 or the motor sense resistors RM01 and RM02 but I suspect a fault in these components would affect normal playback as well! Chris Williams
It's an enigma, that's what it is! This thing's not fixed because it doesn't want to be fixed! Last edited by Chris55000; 23rd Nov 2022 at 9:03 pm. |
23rd Nov 2022, 10:28 pm | #7 |
Chris, I was quite hopeleaa I would be able to find a component fault in all honesty. I was hoping on a bad solder point or bad connection. I cleaned the pot with contact cleaner. The very strange thing is, the pitch knob was engaging at random occasions a few times since I got the unit. I thank you for the detailed information. I will have a look at it again! I will keep you posted and let me know if the random behavior of the pot tells you anything more.
24th Nov 2022, 9:29 am | #8 |
Mine had the same problem; pitch control didn't work. I found that the big power cap had burst and leaked on mine, and it had leaked into one of the big 8 or so pin connectors that seemed to be causing issues. After replacing and cleaning, IIRC the pitch control did start working again, but the last time I used it, it had stopped again.
I think it was an ealry lockdown project that I'd had sitting in a drawer for a few years, and I can't remember if I made notes... but I tend to take lots of pictures, especially with something like this, so I'll check my phone for clues. |
24th Nov 2022, 12:25 pm | #9 |
Thank you again for the replies to everyone. Here is what I did so far:
I first did a continuity check on the wiring between PM01 and PS01 (I presumne this is what Chris meant instead of RS01) as suggested. All good. As suggested by Paul, even before I posted the thread I went over all the caps I could see with a naked eye. Did a very thorough inspection. I could not spot anything visually concerning. There is yellow substance which I believe is industrial glue (see photo). The only place I did not check is the two mounted PCBs on the photo with the black wire passing along. Then I did a resistance check of the trim pot. Starting like shown on the photo I got the following readings: First two pins connected I get 55 ohms with the pot all the way to the left, 54 when centered, 0.7 all the way to the right. Pins 1 and 3 give no reading unless I place the pot close to the far right position. Then I get 61.5 ohms and it goes up the closer I get to the center with a max value reading of 200 ohms before it stops reading. Exact same situation happens between pins 1 and 4 where the center position reads a 60 ohm resistance, rotating left increases the value, right decreases. Pins 2 and 3 gave me a 0.6 ohm R in the center.Left increasing the value, right also increasing the value. At this point of the test I can assume the trim pot is of a 200 ohm value and I think it functions as intended. Taking the above out of the way, I want to deal with the bad cap. It's a 2200 uF, 10v. I called at a store today to ask if they have it and they do but in 16v instead of 10. Would that fit? Last but not least, the IC AN6612. Could I perform any sort of troubleshooting to confirm if it's faulty or not? I've got a rather basic multimeter (see photo). |
24th Nov 2022, 4:28 pm | #10 |
Solved! Now Chris mentioned a switch that turns off the pitch control out of the circuit when REC is engaged. If you go back to my first post and look at IMG_20221123_174426, you will see that switch between the faulty cap and a red component. I've been looking at that switch for a while and wondered what it's meant to do as it was quite detached from the mechanics. After I replaced the cap today, the unit was on and nothing seemed to have changed. The moment I touched that swtich the pitch control suddenly started working again. I then realised, there is a pin attached to the mechanical REC switch that pushes that switch down when recording. That also engages the erase head. Apperanlt, the problem was there. I think it has a bad contact/is dirty. I used some contact cleaner there too. The reason why the pitch did not work is simply becaus I did not trigger the REC button in all these tests. I think that is what user untune87 might be experiencing as well. Worht to check that out.
While I still have the unit opened, I wanted to ask about the volume knob. It seems to cut out the right channel of the headphone out and for the speaker as if I switch to R only there is no output. I've managed to find two sweet spots where the pot will output from both channels. Unfortunately the pot has a long shaft and isn't a regular one. I've cleaned it twice already without much succes. Do you think there is a way to repair it or I should definitely look for a replacement? |
