Old 15th Jul 2020, 11:36 pm   #1
Stormin
Default Panasonic DMR-ES60V connected to a LG43UM7050PLF not playing VHS tapes
I cannot get my VHS/DVD to play VHS tapes. I have tried using a Analogue to digital converter but all I get is a connection but no signal. I have cleaned everything and have checked the capacitors. Is there any way of finding the most likely suspect capacitor.
How do find the cause?
Stormin is offline
Old 16th Jul 2020, 12:16 am   #2
Kyle__B
Default Re: Panasonic DMR-ES60V connected to a LG43UM7050PLF not playing VHS tapes
Sorry but your post is unclear.
When you say the tapes don't play, most people understand that the VCR itself doesn't do its mechanical motions of playing the tape. No whirring and clunking sounds coming out of it, no counter moving on its little screen, etc.
But then you start talking about an analogue to digital converter, which is a different thing entirely.
Kyle__B is offline
Old 16th Jul 2020, 9:39 am   #3
Welsh Anorak
Welsh Anorak's Avatar
I doubt it's a capacitor - they aren't responsible for everything!
Remember the output from the VHS tape isn't relayed to the HDMI socket, just the component and SCART sockets. I'd check that there is an output from those by using an analogue TV. If not it could just be dirty heads. Once you have confirmed this then it's time to bring in the A-D converter.
One step at a time!
Glyn
www.gdelectronics.wales
Welsh Anorak is offline
Old 16th Jul 2020, 5:50 pm   #4
Paul Stenning
Administrator
Paul Stenning's Avatar
The specifications suggest that the TV does have composite video and analogue audio input, which appears to share sockets with component input.
https://www.lg.com/uk/tvs/lg-43um7050plf
If you can set that to composite rather than component mode it would be the best way of connecting the VCR to the TV and wouldn't need any additional boxes.
You would just need a SCART to phono (composite and stereo audio) lead which are still readily available on eBay etc. Make sure you get the right direction, or one that is switchable.
Of course how well a modern 4k TV will handle the somewhat inconsistent composite signal from a typical VCR is another matter. My older LG TV (HD, approx 2012 model) handles it really well though.
Paul Stenning
Paul Stenning is online now
Old 16th Jul 2020, 11:35 pm   #5
Graham G3ZVT
Graham G3ZVT's Avatar
One reading of the OPs post might be that the machine plays CDs but not tapes through the TV, which would suggest it's not a connection issue. We really need more information.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 17th Jul 2020, 2:06 am   #6
Maarten
That would suggest a connection issue as DVDs will play through the HDMI output and VHS tapes won't. The HDMI is connected fine, but the analogue output most likely not.
Maarten is offline
Old 17th Jul 2020, 2:10 am   #7
Graham G3ZVT
But would a DVD+VHS player be recent enough to have HDMI?
Graham.
G3ZVT
Old 17th Jul 2020, 9:56 am   #8
Welsh Anorak
Yes - many were around till quite recently, such as the Panasonic in question and the dreaded Funai Toshiba. It often catches customers out when their new TV won't play their VHS tapes because they're using HDMI instead of SCART
Incidentally in my previous post I incorrectly said component when, as Paul points out, I meant composite.
Glyn
Old 17th Jul 2020, 10:01 am   #9
Maarten
While I can't find the specs, it would make sense for a luxury dual harddisk + freeview recorder to have HDMI. It was probably released around 2004/2005 while HDMI first appeared around 2003. HDMI would likely only be used for digital sources though, as was the case with RGB or component outputs on older model DVD combis.
Maarten is offline
Old 17th Jul 2020, 11:21 am   #10
vidjoman
I recently repaired a Panasonic VHS and DVD unit that only played VHS via the Scart socket. It had Freeview recording to VHS or DVD and played both through the scart to a TV but only Dvd output via the HDMI socket.
vidjoman is online now
Old 18th Jul 2020, 11:04 am   #11
Welsh Anorak
As Paul has pointed out, why not just use the composite inputs for VHS and the HDMI for the DVD? There would be no improvement in using the A-D converter - if anything it might degrade the picture.
Glyn
