Old 5th Dec 2009, 12:58 pm   #41
SeanStevens
SeanStevens's Avatar
Default Re: GPO 706 in trouble.
OK:
Correct. But do remove the regulator (that little slide-in, reversible PCB) and check for an eventual open-circuit between terms: T10 and T2. I say 'eventual', because your meter, set to 'Ohms', will charge up capacitor C3 (0.9uF).
If you do measure a finite, steady resistance here, it's the capacitor at fault and it must be replaced.
There is an open circuit (1 on my ohm meter) between T10 and T2 with the removeable card in or out or upside-down. Now I'm hoping this will give me the naughty component to replace....??
SEAN
There are only 10 types of people, those who understand the binary system, and those who don't.
SeanStevens is offline
Old 5th Dec 2009, 1:15 pm   #42
Station X
Station X's Avatar
Please conform that '1' on your meter does indicate an open circuit. If it does, then with no test leads connected and the meter on ohms range a '1' will be displayed.
The use of terms such as no reading and zero reading is confusing, Better to talk of open circuit (infinite resistance) and short circuit (zero resistance).
Graham. Forum Moderator
Station X is online now
Old 5th Dec 2009, 1:23 pm   #43
SeanStevens
On Ohms - it reads 1 when the probes are not touching - so that is open circuit.
My meter is dodgy, but I think that is correct.
SEAN
Old 5th Dec 2009, 1:26 pm   #44
Station X
Station X's Avatar
Did the reading start low and then rise before settling at open circuit? This would indicate that the capacitor is being correctly charged.
Old 5th Dec 2009, 1:30 pm   #45
Station X
Station X's Avatar
This thread is so long that I've lost touch with what the original problem was and what progress has been made. Does the bell ring on incoming calls?
Old 5th Dec 2009, 1:33 pm   #46
SeanStevens
No, it was straight to open circuit.
SEAN
Old 5th Dec 2009, 1:56 pm   #47
Station X
Station X's Avatar
In that case C3 is faulty. Check for cracks in the tracks leading to it.
Old 5th Dec 2009, 2:04 pm   #48
Station X
Station X's Avatar
I should have said C1B is faulty. This is a 706, not a 746.
