Old 7th Aug 2020, 7:15 pm   #1
Bookman
Default TEAC 1230 Translation Query
There is a very slight wobble on my take up reel which does not affect play but the operating manual would suggest otherwise; the attached refers. Am I right in saying the wording should read "if reel is wobbling"?
Everything else is fine and set up nicely but I worry that the motor shaft may have had a knock in the past.
Anyone have any comments?
Joe
Bookman is offline
Old 7th Aug 2020, 8:11 pm   #2
ms660
ms660's Avatar
Default Re: TEAC 1230 Translation Query
If the reel is wobbling don't adjust the reel height until the wobbly reel has been sorted out.
Lawrence.
ms660 is offline
Old 8th Aug 2020, 11:55 am   #3
Bookman
Thanks Lawrence,
My use of "wobble" is perhaps misleading as it does not relate to the reason that a wobble exists. The problem emanates from a slight eccentricity or radius of gyration that exists on a brass gizmo that is fitted to the drive motor shaft.
The gizmo is circa 2" inches long and has a circa 3/4" diameter collar that drives the counter. It then has a circa 1/4" shaft that has been turned with a threaded hole in the end. The take up reel shaft tension spring fits over this shaft and the threaded hole provides the ability to adjust the tension.
It is this 1/4" part of the gizmo that is slightly eccentric.
Any chance anyone may know where a spare could be obtained or indeed where a new item could be made. In this if I had a lathe I would have a go at making one. Similarly, someone with good eyes might be able use a hammer to tap it back in position following its removal from the shaft.
Joe
Bookman is offline
