Old 5th Aug 2020, 4:41 pm   #1
HBWOODY
Default Anachem Origo psu trip problem
I have been unable to find any user manual and circuit diagram for this PSU.
It switches on OK but is stuck in trip mode. There is a damaged resistor which can be seen in the attached photos (no value markings on it)which may well be causing the problem. Is there any way of working out the value of the resistor or will I just have to dump the PSU in a skip.
ID:	212772   Click image for larger version
ID:	212773   Click image for larger version
HBWOODY is offline
Old 5th Aug 2020, 6:28 pm   #2
ColinTheAmpMan1
ColinTheAmpMan1's Avatar
Default Re: Anachem Origo psu trip problem
Is this device for Gel Electrophoresis, by any chance? Why not contact Anachem?
Colin.
ColinTheAmpMan1 is offline
Old 5th Aug 2020, 7:37 pm   #3
HBWOODY
Have tried contacting Anachem but have had no response. Do not know what Gel Electrophoresis is.
HBWOODY is offline
Old 5th Aug 2020, 8:46 pm   #4
MotorBikeLes
Is that a blown resistor? It looks more like a porcelain fuse to me. What is the identifier on the circuit. It looks to me as if something nearby or just downstream is short circuited. Do a few resistance measurements. There are usually clues on the board if you read everything that is silk screened.
Les.
MotorBikeLes is offline
Old 6th Aug 2020, 7:07 am   #5
HBWOODY
It is marked as R7 on the circuit board.
HBWOODY is offline
