11th Apr 2020, 8:46 pm | #1 |
N diagram /circuit diag anyone
Found this socket in amongst my old sockets . From what I remember it's fitted to older BT systems to ring an extension bell from extension phones and needs a 50v supply of correct polarity ( something which a lot of customers did not realise , resulting in one of the power resistors -R5/R6 ?, going up in smoke).
All I can find on the socket is a number DPA1448A which means little to me as I never got involved in BT systems. Anyone from BT systems remember this one and point me to an N diag or circuit diagram please. |
11th Apr 2020, 10:05 pm | #2 | |
Re: N diagram /circuit diag anyone
11th Apr 2020, 10:21 pm | #3 |
It's got the old style BT logo on the front The short line with a longer line at right angles ,with a set of two dots to the right.And all in a circle.
From memory ,I seem to remember this type of socket fitted to possibly a Herald extension, to let an extension bell ring from a system extension. Looking at the socket, it seems so similar to a "ringing generator 2A" , which was operatd on a mains supply. Last edited by Oldcodger; 11th Apr 2020 at 10:36 pm. |
12th Apr 2020, 8:02 am | #4 |
You mean this one:
12th Apr 2020, 8:05 am | #5 |
By the way, I misremembered it as having three dots, which would have made the upper bar a "B" in Morse code.
12th Apr 2020, 1:51 pm | #6 | |
The current logo is so unimaginative, but no doubt someone got richer by designing it.
-- Graham. G3ZVT |
12th Apr 2020, 3:25 pm | #7 |
That's the one ,Dave.
Thinking back, this socket was fitted to one port on something like a Herald ( possible Pentara) with a four wire termination on it ,along with 50v from the switch and a bell out pair. I've never fitted one as I spent most of my time replacing BT systems with Panasonic systems ( except when the firm did either TIG or MIG welding when I sent the order back for a technical inspection as Panasonic did not like MIG/TIG). |
12th Apr 2020, 5:35 pm | #8 |
I notice that you mentioned the socket last October in the context of ringer boosting (post no. 7). Found while googling the number at the top.
12th Apr 2020, 9:18 pm | #9 |
Dave- I mentioned both variants as solutions to ringing, with no clue to what they were/what they did or circuits.
13th Apr 2020, 6:41 pm | #10 |
Hi, I once owned one of these sockets which came with an Ambassador 2+4 system.
From memory the socket allows an additional bell to be associated with the system phone connected to it. I think there's a link in the system phone which has to be opened to allow the external bell to operate. I can see no reason why the socket wouldn't also operate on the the Senator 5 + 10 and possibly other systems of a similar design which use dedicated system phones. Regards Andrew |
13th Apr 2020, 7:17 pm | #11 |
If it works with the Ambassador, I would expect it also to work with the Senator, given that, as far as I know, the only real functional difference between them is how exchange lines are accessed.
14th Apr 2020, 4:37 pm | #12 | |
But back OT- anyone got a circuit diagram for one of these ? |
